ERROR: -6....I cant connect to Home assistant Green eventhough it is connected to same network
After the update it went safe mode recovery and cant restart or anything IF NOTHING WORKS … need assistance with how to start it from beginning as a fresh ha green,any help regarding this would be pretty appreciated… Thank you
Check out these links
I tried it ,it is not working… it had some kind of error like the whole interface went red and there’s no overview and the other boards that i added… The main problem now is I cant connect my home assistant through http://homeassistant.local:8123 or through my http://:8123… even though it is connected to the same network pls any help would be appreciated
First try connecting a physical console:
And see what that says. You may be able to fix something there. If not then use the reset procedure linked above.
If possible, from a PC, open CMD on your PC and enter ping homeassistant.local -4 and if it shows a reply with the following, it’s running and may point to some other issue.
 Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 4ms, Maximum = 10ms, Average = 6ms
Minimum = 0ms, Maximum = 1ms, Average = 0ms so what is the problem is it running properly …
when i access through the hdmi it said home assistant cli is not starting and docker is empty without home assistant OS-cli and home assistant OS-supervisor
I’d take Tom’s advice and do a full reset with the instructions above. It appears to me there was an issue during the installation of the OS.
It may be fixable from the prompt, but it’s not worth the effort considering you are still early in the installation process.
when i accessed through the hdmi it said home assistant cli is not starting and docker is empty without home assistant OS-cli and home assistant OS-supervisor
and when i tried to reboot it and it restarted and it again saying cli not starting and docker is again empty
Some commands to try fro the CLI:
ha core rebuild
ha host update
I don’t know if either will help.
https://www.home-assistant.io/common-tasks/os#home-assistant-via-the-command-line
after connecting through keyboard and monitor its saying home assistant OS-cli and home assistant OS-supervisor
Oh you don’t even have the CLI.
Re-image and restore backup is your best way forward.
i tried pull the container after pulling it again showing not available
what should i do and I want to reflash my OS using USBdrive(pendrive) is it possible
Follow the instructions in the links you have been sent multiple times already.
so can I use pendrive or not ,Sir
