Error ‘AddonManager.install’ blocked from execution, system is not healthy - docker
Does someone know what this error is? I can’t update and install any addon and Home Assistant Core too. The “ha res inf” command gives me:
unhealthy:
- docker
docker --version is:
Docker version 20.10.21, build baeda1f
The docker is working fine apart from Home Assistant.
Home Assistant log doesn’t have anything specific, only:
2022-11-08 20:00:08.002 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_logviewer/install - 'AddonManager.install' blocked from execution, system is not healthy - docker
Thanks for help!
