Hello, I get the following error when removing the broken integration “seatconnect”:
Although I click on Remove previous integration and get success notification, if I restart HA initial error is still there.
My HA log says:
Riga 18: 2025-03-07 13:41:51.638 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration 'seatconnect' not found.
Riga 20: 2025-03-07 13:41:53.676 ERROR (MainThread) [homeassistant.setup] Setup failed for 'seatconnect': Integration not found.
I tried also to re-import the integration again (since it’s not active on HACS anymore I needed to import it manually) but even if I delete it from GUI I get the same annoying result.
How can I get out of this?
