Error after update to pyton 3.6
After updating my virtual enviroment i get this error. Any idea to fix it?
 2017-11-08 20:10:42 ERROR (MainThread) [homeassistant.components.media_player] Error on device update!
      File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 216, in async_add_entity
        yield from entity.async_device_update(warning=False)
      File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 309, in async_device_update
        yield from self.hass.async_add_job(self.update)
      File "/usr/local/lib/python3.6/asyncio/futures.py", line 331, in __iter__
        yield self  # This tells Task to wait for completion.
      File "/usr/local/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
        future.result()
      File "/usr/local/lib/python3.6/asyncio/futures.py", line 244, in result
        raise self._exception
      File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
      File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/components/media_player/spotify.py", line 164, in update
        self.refresh_spotify_instance()
      File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/components/media_player/spotify.py", line 146, in refresh_spotify_instance
        self._oauth.is_token_expired(self._token_info))
    AttributeError: 'SpotifyOAuth' object has no attribute 'is_token_expired'
Having the same issue after upgrading python to 3.6 yesterday. Have you had any luck finding an answer?
Hassbian 58.1
Did you see this?
https://github.com/home-assistant/home-assistant/issues/7286
I did not. That did the trick. Thanks.
I don’t get it to work. Can you please post how you solved it?
I did the following (this assumes you’re using hassbian with a virtual environment)
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
pip3 install --upgrade git+https://github.com/happyleavesaoc/spotipy@connect-api
The pip3 command came from the link RobDYI posted above.
EDIT: Just an FYI. I still appear to be getting errors in the log about Spotify, but the player shows up in HA and works. I was able to play/pause Spotify on my phone from HA on my desktop.
