The previous node is a switch. its output is an object, but none of the properties are named any of, “node_id”, “parameter”, or “value”. I just upgraded to 0.86.1 and its offline for some reason, I’ll get more info about the flow posted when it gets back up and running.
In the meantime, I did test it with a inject node and a fresh new call-service node. This worked. So I connected the injector to my failing node and that failed. When I get a chance, I’ll try putting a node in between the call service and the switch. Maybe a node that sets the parameters for the service…I’ll definitely post up my whole flow later anyway.
My flow looks like this:
"id": "7700f281.36dcac",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": ""
"id": "4ca72a5.6412ed4",
"type": "tail",
"z": "7700f281.36dcac",
"name": "ozwlog tail",
"filetype": "text",
"split": true,
"filename": "/config/OZW_Log.txt",
"x": 80,
"y": 20,
"wires": [
"cf64bab3.f692f8"
"id": "cf64bab3.f692f8",
"type": "switch",
"name": "Only Config Reports",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "regex",
"v": "Info, Node\\d{3}, Received Configuration report",
"vt": "str",
"case": true
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 280,
"y": 20,
"wires": [
"8704eae2.9ca998"
"id": "8704eae2.9ca998",
"type": "function",
"name": "Extract Variables",
"func": "var regExp =/Info, Node0*(\\d+), Received Configuration report: Parameter=(\\d+), Value=(\\d+)/\nvar results = regExp.exec(msg.payload);\nvar obj = {data: { nodeId: results[1], parmIndex: results[2], parmValue: results[3]}};\n\nmsg.payload = obj;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 510,
"y": 20,
"wires": [
"c7492ad3.d78348"
"id": "c7492ad3.d78348",
"type": "switch",
"name": "Hold / ESM?",
"property": "payload.data.parmIndex",
"rules": [
"t": "eq",
"v": "76",
"vt": "str"
"t": "eq",
"v": "77",
"vt": "str"
"checkall": "false",
"repair": false,
"outputs": 2,
"x": 110,
"y": 120,
"wires": [
"15645245.205c9e"
"d95350c8.ed79b"
"id": "d95350c8.ed79b",
"type": "switch",
"name": "ESM",
"property": "payload.data.parmValue",
"rules": [
"t": "eq",
"v": "1",
"vt": "str"
"t": "eq",
"v": "0",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 310,
"y": 160,
"wires": [
"id": "15645245.205c9e",
"type": "switch",
"name": "Hold/Run",
"rules": [
"t": "eq",
"v": "0",
"vt": "str"
"t": "eq",
"v": "1",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 320,
"y": 100,
"wires": [
"1f41e685.8cc809"
"outputLabels": [
"hold",
"run"
"id": "f83f984c.1a5af8",
"type": "catch",
"name": "",
"scope": null,
"x": 700,
"y": 60,
"wires": [
"id": "1f41e685.8cc809",
"type": "api-call-service",
"name": "",
"server": "d812fdda.9bbad",
"service_domain": "input_boolean",
"service": "turn_off",
"data": "{\"entity_id\":\"input_boolean.trane_downstairs_hold\"}",
"render_data": false,
"mergecontext": "",
"output_location": "payload",
"output_location_type": "msg",
"x": 560,
"y": 120,
"wires": [
"id": "ccd7f8e7.a2f248",
"type": "inject",
"name": "",
"topic": "",
"payload": "",
"payloadType": "date",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 320,
"y": 260,
"wires": [
"1f41e685.8cc809"
"id": "d812fdda.9bbad",
"type": "server",
"z": "",
"name": "Home Assistant"
Clicking the inject node works, having it run from the flow doesn’t.
