Hello everyone,
I’m using an old custom custom component for a zigbee controler (zigate), wich has not been updated since a long time, because I cannot easily repair some of my devices if I change to ZHA.
I forked the repo some time ago to do changes to make it compatible when there was an error updating home assistant with breaking changes.
Here is the repo : homeassistant-zigate.
Today I tried to update from 2024.3.3 to 2024.5.4, but after the update, this component is no longer working, giving me this error :
Enregistreur: homeassistant.setup
Source: setup.py:322
S'est produit pour la première fois: 21:16:05 (1 occurrences)
Dernier enregistrement: 21:16:05
Setup failed for custom integration 'zigate': Unable to import component: cannot import name 'ENTITY_ID_FORMAT' from 'homeassistant.components.group' (/usr/src/homeassistant/homeassistant/components/group/__init__.py)
File "/usr/src/homeassistant/homeassistant/loader.py", line 981, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1041, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 144, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/zigate/__init__.py", line 17, in <module>
from homeassistant.components.group import \
ImportError: cannot import name 'ENTITY_ID_FORMAT' from 'homeassistant.components.group' (/usr/src/homeassistant/homeassistant/components/group/__init__.py)
File "/usr/src/homeassistant/homeassistant/setup.py", line 322, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1001, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 993, in async_get_component
comp = self._get_component()
I’m not able to find why I have this problem.
I tried to look at the init.py file where I can see this command :
ENTITY_ID_FORMAT as GROUP_ENTITY_ID_FORMAT
but I do not understand why there is this problem.
Could someone help my figure this out ?
Thanks a lot.
