Error configuration Google assistant on HA 65.0
Good Morning, I have a problem with Google Asssitant, since I updated to version 65.0 of HA tells me that my configuration is wrong and that the component can not be started, someone knows how to solve ??
I use Hass.io Cattura
Your logs should tell you what’s wrong.
Likely it is because you have stuff like: type: light defined which is not longer working with the latest version (I was experiencing the same in my setup)
My configuration is:
google_assistant:
  project_id:
  client_id:
  access_token:
  api_key:
  exposed_domains:
    - switch
    - light
    - group
    - climate
  entity_config:
    sensor.dht_sensor_temperature:
      expose: true
      aliases:
        - temperature room
      type: climate
    sensor.dht_sensor_humidity:
      expose: true
      aliases:
        - humidity room
      type: climate
For now Ihave made a restore of a previous Backup
As was said, and as is noted in the release notes, type: is no longer supported.
You could set up a dummy climate device (using the generic climate component) instead, and use that.
I removed the temperature and humidity sensors but I need to be able to ask google assitant the temperature and humidity as I do to reinsert them without errors?
is it okay using a DHT11 sensor?
for humidity??
No idea I’m afraid, but I’d have a look at the components and see if something supports that.
