Hi, very new to Home Assistant.
I’m trying to install device on my esp32 through wireless. But got this error.
I have searched many same issues in Internet. I have tried built OTA web update on my esp32, write the code about connecting wifi, setting ArduinoOTA port 3232 and letting the on-board led blinking, it’s running. Even check the ESP32 IP on Advanced IP Scanner correctly. However, still not solute this problem.
This is my esphome YAML. Thanks for helping.
esphome:
platform: ESP32
board: nodemcu-32s
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "b111dfdef449e288adf370eb372847b3"
wifi:
ssid: "CCSPE-AP-02"
password: "mypass"
# use_address: 192.168.0.193
ap:
ssid: "Testdata Fallback Hotspot"
password: "Cq1w1hD6cYvC"
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.0.126
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.0.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
captive_portal:
This is error code.
========================= [SUCCESS] Took 11.36 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.0.126
ERROR Connecting to 192.168.0.126:3232 failed: [Errno 111] Connection refused
