I want to rename my ESPHome device from ‘watermeter’ to ‘meterkast-controller’ but I get this error:
INFO Reading configuration /config/esphome/watermeter.yaml...
Updating /config/esphome/watermeter.yaml to /config/esphome/meterkast-controller.yaml
INFO Reading configuration /config/esphome/meterkast-controller.yaml...
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block mapping
in "/config/esphome/meterkast-controller.yaml", line 36, column 5:
- platform: pulse_counter
expected <block end>, but found '<scalar>'
in "/config/esphome/meterkast-controller.yaml", line 39, column 34:
Rename failed. Reverting changes.
I don’t understand what is wrong. When I validate the device everything is valid:
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
# Optional manual IP
manual_ip:
static_ip: ..................
gateway: ...............
subnet: .................
dns1: .................
ap:
ssid: "Watermeter Fallback Hotspot"
password: "xxxxxxxxxxxxxxxxxxxx"
captive_portal:
# ⬇ watermeter ⬇ #
pin: D2
state_class: measurement
update_interval: 1s
unit_of_measurement: L
accuracy_decimals: 1
filters:
- multiply: 0.01342282
# ⬇ Totaal watermeter ⬇ #
total:
icon: "mdi:cube-outline"
unit_of_measurement: "m³"
device_class: water
state_class: total_increasing
accuracy_decimals: 4
filters:
- multiply: 0.0008
- platform: wifi_signal
name: "Watermeter WiFi Signal"
update_interval: 60s
- platform: uptime
binary_sensor:
- platform: gpio
pin: D5
device_class: door
- platform: gpio
pin: D6
device_class: door
