Error during setup of component tahoma
I´m running Hass.io 0.71.0 on a Raspberry 3. Everything works fine, but I can´t get the Tahoma component to work. Always getting an invalid Config message. Don´t know what I´m doing wrong.
My Configuration:
tahoma:
username: myusername
password: mypassword
Log shows the following errors:
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 146, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/tahoma.py”, line 67, in setup
scenes = api.get_action_groups()
File “/usr/lib/python3.6/site-packages/tahoma_api/tahoma_api.py”, line 524, in get_action_groups
group = ActionGroup(group_data)
File “/usr/lib/python3.6/site-packages/tahoma_api/tahoma_api.py”, line 911, in init
self.__last_update = data[‘lastUpdateTime’]
KeyError: ‘lastUpdateTime’
Would be great, if anybody could help me.
i’ve the same problem here with my setup. Did you find a way to make it works ?
Arnaud
unfortunately I couldn’t solve the problem.
At the moment I´m using Ha-bridge, to use Alexa voice control. Maybe thats also a solution for you. I think with homebridge it should work for siri too.
I´ll let you know if i find a solution.
