Hi there. I was modifying some ESP for changing the SSID of the wifi. On this one specific, i uploaded the code over serial from the raspberry running HA, and right now i can control lights from the dashboard and everything, even on Esphome builder i can see the logs, but for a reason when uploading over the air, it doesnt "detect" the ESP. it says "ERROR All specified devices ['OTA'] could not be resolved. Is the device connected to the network? If you know the IP, set 'use_address' in your network config."
This is my config file currently, thanks for any help.
esphome:
friendly_name: esp2
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "i erased this"
wifi:
ssid: "Aruba"
password: "12345678"
use_address: 192.168.50.197
ap:
ssid: "Esp2 Fallback Hotspot"
switch:
- platform: gpio
pin: 27
inverted: True
on_turn_on:
- delay: 0.5s
- switch.turn_off: test1
- platform: gpio
pin: 26
inverted: True
- platform: gpio
pin: 5
inverted: True
- platform: gpio
pin: 18
inverted: True
binary_sensor:
- platform: gpio
pin:
number: 15
mode: INPUT_PULLUP
internal: true
on_state:
then:
- switch.toggle: relayt1
- platform: gpio
pin:
number: 4
mode: INPUT_PULLUP
internal: true
on_state:
then:
- switch.toggle: relayt2
captive_portal:
