Error fetching system info for cloud
Am seeing the following in the home-assistant.log file. Not able to find anything on the forum. Has anyone seen this? It appears to be coming from the https://www.home-assistant.io/integrations/system_health/ integration. I am able to see System Health in the Configuration -> Info though. I haven’t setup to use the Home Assistant Cloud feature.
2020-12-04 16:01:04 ERROR (MainThread) [homeassistant.components.system_health] Error fetching system info for cloud - can_reach_cloud
  File "/usr/src/homeassistant/homeassistant/components/system_health/__init__.py", line 212, in async_check_can_reach_url
    await session.get(url, timeout=5)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 551, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 907, in start
    self._continue = None
  File "/usr/local/lib/python3.8/site-packages/aiohttp/helpers.py", line 656, in __exit__
    raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
same problem
same problem here
