This error occurs when you read a property or call a method on a null object . That’s because the DOM API returns null for object references that are blank. An object is expected somewhere and wasn’t provided. So, you will get null is not an object error if the DOM elements have not been created before loading the script. In JavaScript , null is not an object; and won’t work. You must provide a proper object in the given situation.
We can resolve this type of issues by adding an event listener that will notify us when the page is ready. Once the addEventListener is fired, the init() method can make use of the DOM elements.
document.addEventListener('readystatechange', function() {
if (document.readyState === "complete") {
init();
since this is about the only direct thread on the exact issue I am experiencing, I’d like to add this happens on views with a conditional card (in a horizontal-stack), of which the condition isn’t evaluated to True.
Since that is rather a normal situation, it would be very nice this error wouldn’t flood the log. After some more investigation, I seems to be happening on the stack-in-card, and on the state-switch with a default: '' if the entity doesnt have a state listed in the possible states.
