Error handling request from 172.30.33.5
I’m running HA on Yellow Core=2025.3.4, Supervisor=2025.03.4, Operating System=15.1, Frontend=20250306.0
Since yesterday I am getting errors that key components won’t load
I have tried installing a back up that predates the error and even a clean install but nothing seems to work making me think that there is something outside HA blocking the calls, but I can’t work it out. Anu ideas? TIA
2025-04-02 07:19:04.894 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.33.5
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 198, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 212, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 229, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 293, in core_proxy
  File "/usr/src/supervisor/supervisor/api/proxy.py", line 120, in api
    path = request.match_info["path"]
Hello, I have the same problem; after updating to HA 2025.10.1 two integrations are giving me an error. I tried to uninstall one of them. And when I try to install it again, I get the error ‘500 Internal Server Error Server got itself in trouble’.
Have you solved it?
The problem went with the next HA patch release.
