Error hassio
I got this errors in hassOS, home assistant 0.77.3, can someone help what this is
18-09-05 16:11:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-09-05 16:21:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-09-05 16:21:28 INFO (MainThread) [hassio.homeassistant] Updated HomeAssistant API token
18-09-05 16:31:29 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-09-05 16:41:30 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-09-05 16:51:31 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-09-05 16:51:31 INFO (MainThread) [hassio.homeassistant] Updated HomeAssistant API token
18-09-05 17:01:39 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-09-05 17:02:16 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 390, in start
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 352, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 106, in impl
    return await handler(request)
  File "/usr/local/lib/python3.7/site-packages/hassio/api/security.py", line 36, in token_validation
  File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 231, in websocket
    await server.send_str(client_read.result())
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_ws.py", line 252, in receive_str
    msg.data))
TypeError: Received message 257:None is not str
18-09-05 17:02:17 ERROR (MainThread) [aiohttp.server] Unhandled exception
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 410, in start
    await resp.prepare(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 300, in prepare
    return await self._start(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 608, in _start
    return await super()._start(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 367, in _start
    await writer.write_headers(status_line, headers)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 110, in write_headers
    self._write(buf)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 67, in _write
    raise ConnectionResetError('Cannot write to closing transport')
ConnectionResetError: Cannot write to closing transport
18-09-05 17:02:34 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request initialze
18-09-05 17:02:47 INFO (MainThread) [hassio.api.proxy] Websocket access from a0d7b954_appdaemon3
18-09-05 17:04:33 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request initialze
18-09-05 17:04:40 INFO (MainThread) [hassio.api.proxy] Websocket access from a0d7b954_appdaemon3
18-09-05 17:05:16 WARNING (SyncWorker_18) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:16 WARNING (SyncWorker_8) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:16 WARNING (SyncWorker_4) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:16 WARNING (SyncWorker_1) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:16 WARNING (SyncWorker_11) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:17 WARNING (SyncWorker_6) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:17 WARNING (SyncWorker_8) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost
18-09-05 17:05:17 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request running
18-09-05 17:05:19 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/config access from a0d7b954_appdaemon3
18-09-05 17:05:20 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
`> Blockquote`
