Error in automation after update
I am running Home Assistant OS, Core 2026.1.3, Supervisor 2026.01.1, Operating System 17.0 and Frontend 20260107.2
After an upgrade of the Core, the automation is broken. I think this is the root-cause for some other integration fails, e.g. Shelly.
I do not know where to look for to get the error fixes, pls. help me, my system is not working any more!
KR,
Christof
Logger: homeassistant.config
Quelle: config.py:1153
Erstmals aufgetreten: 09:59:22 (1 Vorkommnis)
Zuletzt protokolliert: 09:59:22
Unknown error calling automation config validator - 'NoneType' object is not subscriptable
  File "/usr/src/homeassistant/homeassistant/config.py", line 1153, in async_process_component_config
    await config_validator.async_validate_config(hass, config), []
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 328, in async_validate_config
    await _try_async_validate_config_item(hass, p_config)
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 306, in _try_async_validate_config_item
    return await _async_validate_config_item(hass, config, False, True)
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 220, in _async_validate_config_item
    automation_config[CONF_TRIGGERS] = await async_validate_trigger_config(
        hass, validated_config[CONF_TRIGGERS]
  File "/usr/src/homeassistant/homeassistant/helpers/trigger.py", line 1117, in async_validate_trigger_config
    conf = await platform.async_validate_trigger_config(hass, conf)
  File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 61, in async_validate_trigger_config
    return await async_validate_device_automation_config(
        hass, config, TRIGGER_SCHEMA, DeviceAutomationType.TRIGGER
  File "/usr/src/homeassistant/homeassistant/components/device_automation/helpers.py", line 56, in async_validate_device_automation_config
    platform = await async_get_device_automation_platform(
        hass, validated_config[CONF_DOMAIN], automation_type
  File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 171, in async_get_device_automation_platform
    integration = await async_get_integration_with_requirements(hass, domain)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 61, in async_get_integration_with_requirements
    return await manager.async_get_integration_with_requirements(domain)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 179, in async_get_integration_with_requirements
    await future
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 168, in async_get_integration_with_requirements
    await self._async_process_integration(integration, done)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 191, in _async_process_integration
    await self.async_process_requirements(
        integration.domain, integration.requirements, integration.is_built_in
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 308, in async_process_requirements
    await self._async_process_requirements(name, missing)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 340, in _async_process_requirements
    installed, failures = await self.hass.async_add_executor_job(
        _install_requirements_if_missing, requirements, kwargs
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 124, in _install_requirements_if_missing
    if pkg_util.is_installed(req) or _install_with_retry(req, kwargs):
  File "/usr/src/homeassistant/homeassistant/util/package.py", line 96, in is_installed
    if (installed_version := version(req.name)) is None:
  File "/usr/local/lib/python3.13/importlib/metadata/__init__.py", line 987, in version
    return distribution(distribution_name).version
  File "/usr/local/lib/python3.13/site-packages/importlib_metadata/__init__.py", line 557, in version
    return md_none(self.metadata)['Version']
TypeError: 'NoneType' object is not subscriptable
No, this did fix another issue, but not this one. The logs still show multiple errors, all of them look the same:
    await future
# ha core check
Processing... Done.
Error: Testing configuration at /config
Fatal error while loading config: 'NoneType' object is not subscriptable
Failed config
  General Errors:
Successful config (partial)
This is the way I fixed it:
