Error in automations
I’am getting all the time this error in automation
Logger: homeassistant.config
Source: config.py:464
First occurred: December 19, 2021, 8:56:50 AM (25 occurrences)
Last logged: 8:12:51 AM
Invalid config for [automation]: required key not provided @ data[‘action’]. Got None required key not provided @ data[‘trigger’]. Got None. (See /config/configuration.yaml, line 17).
I suspect it is referring to this automation (which works anyway):
alias: Battery Low - Pro
description: Battery have to be recharged
  • platform: numeric_state
    entity_id: sensor.pro_voltage
    below: ‘2.6’
    for:
    hours: 2
    minutes: 0
    seconds: 0
    milliseconds: 0
    condition: []
  • service: telegram_bot.send_message
    message: ‘Battery D1-Pro low : {{ states(’‘sensor.pro_voltage’’) }} V’
    title: ALARM
    mode: restart
    max: 6
Line 17 in configuration.yaml is : group: !include groups.yaml
Do you have any clue why I’m getting such notification?
Thank you in advance
You need to format the code with the code block.
It’s impossible to help when we can’t see proper format of the code.
