Yes, i know…
In this case i must rewrite all the templates i have actually?
Yes, i know…
No, not likely. it only affects certain templates and most people don’t really notice.
I’m using it on 117.3 right now and I only had a few templates that needed conversions and they were all related to a custom component configuration (hass-variables)
Hmmm…I think that’s backwards based on this statement from that post:
I know it’s definitely a bit confusing.
What’s worse is that becxause of a bug in the template editor makes it difficult to test this functionality.
I recommend giving it a try and see what happens.
If i use the template in the model editor i get the right values, so why the script is wrong ???
I do have the same problem since 118.3
entity_id: light.garten_oben
brightness: "200"
color_temp: '{{ state_attr("light.wohnzimmer_stlmp_unten","color_temp") |int }}'
Logger: homeassistant.components.websocket_api.http.connection
Source: core.py:1405
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 17:35:41 (5 occurrences)
Last logged: 17:49:43
[1741517536] expected int for dictionary value @ data['color_temp']
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 135, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1405, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 340, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 336, in _exec
v = func(v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 338, in _exec
v = func(path, v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected int for dictionary value @ data['color_temp']
By the way: This works so far:
- service: light.turn_on
entity_id: light.garten_unten
brightness: "250"
xy_color:
- "{{state_attr('wohnzimmer_fenster_oben','xy_color')[0]}}"
- "{{state_attr('wohnzimmer_fenster_oben','xy_color')[1]}}"
So what is the difference?
I created an issue on Github #43730
Hi all, does anybody have found a solution for this?
Meanwhile, the code which works so far suddenly throws an error since yesterday evening.
Why yesterday, why not from the beginning? I’m confused.
I believe not. I luckily came across this post after being confronted with the same error. I wanted to dynamically generate the values for rgb_color on a service call for lights on. Eventually this worked;
entity_id: light.woonkamer_woonkamer_plafond_midden
rgb_color:
- "{{ (range(0, 255)|random|int) }}"
brightness: 159
