Error in docker logs regarding when trying to intergrate with frigate
Hi!
I am using HA in docker:
Home Assistant 2023.6.3
Frontend 20230608.0 - latest
I am trying to add Frigate integration to HA and getting the following error in HA logs:
2023-07-04 09:15:29.439 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pytz==2022.7: ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/.local'
Check the permissions.
2023-07-04 09:15:49.693 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pytz==2022.7: ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/.local'
2023-07-04 09:16:10.965 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pytz==2022.7: ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/.local'
2023-07-04 09:16:10.966 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 149, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 71, in post
    result = await self._flow_mgr.async_init(
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 845, in async_init
    flow, result = await task
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 863, in _async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 962, in async_create_flow
    await _load_integration(self.hass, handler_key, self._hass_config)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2026, in _load_integration
    await async_process_deps_reqs(hass, hass_config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 418, in async_process_deps_reqs
    await requirements.async_get_integration_with_requirements(
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 52, in async_get_integration_with_requirements
    return await manager.async_get_integration_with_requirements(domain)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 171, in async_get_integration_with_requirements
    await self._async_process_integration(integration, done)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 186, in _async_process_integration
    await self.async_process_requirements(
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 252, in async_process_requirements
    await self._async_process_requirements(name, missing)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 290, in _async_process_requirements
    raise RequirementsNotFound(name, list(failures))
homeassistant.requirements.RequirementsNotFound: Requirements for frigate not found: ['pytz==2022.7'].
Then I added this to volumes:
- /stg04/HomeAssistant/config/.local:/.local
Which resulted in this error:
2023-07-04 09:25:40.104 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pytz==2022.7: ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/.local/lib'
2023-07-04 09:26:00.703 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pytz==2022.7: ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/.local/lib'
2023-07-04 09:26:21.096 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pytz==2022.7: ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/.local/lib'
2023-07-04 09:26:21.097 ERROR (MainThread) [aiohttp.server] Error handling request
Does anyone have a creative fix for this? Is there an environment variable that controls the directory location?
Never mind! looks like HA docker needs to run as root. Removed my user restriction in docker-compose.yml and was able to install Frigate integration. :sigh:
hi Nabheet, could you tell me how you did that exactly? my docker.compose.yml looks like this:
homeassistant:
    image: ghcr.io/home-assistant/home-assistant:latest
    container_name: homeassistant-qb
    user: ${UID?"UID variable not set. Execute ./setenv.sh"}:${GID?"GID variable not set. Execute ./setenv.sh"}
    restart: unless-stopped
    environment:
      - TZ=Europe/Brussels
    ports:
      - "8123:8123"
    volumes:
      - "./homeassistant/config:/config"
What should I change?
