Error in Lambda using HA sensor
I am trying to use a HA sensor value within ESPHome.
I am obviously missing something here - any help appreciated :slight_smile: Thank you!
  - platform: homeassistant
    entity_id: sensor.solcast_pv_forecast_forecast_today
time:
  timezone: NZST-12NZDT,M9.5.0,M4.1.0/3
  on_time:
      - seconds: 0
        minutes: 0
        hours: 6
        then:
          - if:
              condition:
                lambda: 'return id(energy_prediction_today)  > 40.0;'
              then:
                - logger.log: "lambda is true"
Error:
/config/esphome/hwc-monitor.yaml: In lambda function:
/config/esphome/hwc-monitor.yaml:396:41: error: expected primary-expression before 'float'
  396 |                 lambda: 'return (id(energy_prediction_today) | float ) > 40.0;'
/config/esphome/hwc-monitor.yaml:396:40: error: expected ')' before 'float'
*** [.pioenvs/hwc-monitor/src/main.cpp.o] Error 1
I’m not an ESPHome expert, but I think you just need to tell it to retrieve the state:
lambda: "return id(energy_prediction_today).state  > 40.0;"
Thank you! Did not see that for looking….
