Error in loading openzwave
Why this?
pi@hassbian:/srv/homeassistant/src/open-zwave-control-panel $ dir
config   LICENSE                ozwcp      ozwcp.html  test.sh     webserver.cpp  zwavelib.cpp
cp.html  Makefile               ozwcp.cpp  ozwcp.o     testusb.sh  webserver.h    zwavelib.o
cp.js    openzwavetinyicon.png  ozwcp.h    README      TODO        webserver.o
pi@hassbian:/srv/homeassistant/src/open-zwave-control-panel $ sudo systemctl stop  home-assistant.service
Failed to stop home-assistant.service: Unit home-assistant.service not loaded.
pi@hassbian:/srv/homeassistant/src/open-zwave-control-panel $ sudo ./ozwcp -p 8888
2017-04-22 13:17:26.149 Error, Cannot find a path to the configuration files at ./config/. Exiting...
2017-04-22 13:17:26.150 Error, Exception: Options.cpp:91 - 1 - Cannot Find Configuration Files
Error: Options.cpp:91 - Cannot Find Configuration Files
Is this new or did you start getting this error message when you upgraded to .43.0. I have a similar Z-wave error after upgrading.
My z-wave has disappeared but I’m not sure if it’s related to the update - I was wanting to test a minor update via docker to 42.4 before the 43.0 update I expected tomorrow (Australia time) and got caught out by the update without backing up the docker container first so not sure if I can roll back to test.
I don’t have any z-wave errors though - component appears to have loaded and I now have a z-wave entry under configuration on the hamburger menu but no z-wave entities or devices.
