Why do I get this in my log like every second? Can’t se anything wrong:
2023-01-07 12:09:18.812 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: ‘dict object’ has no attribute ‘sonnen’ when rendering ‘{{ value_json.sonnen }}’
2023-01-07 12:09:19.807 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: ‘dict object’ has no attribute ‘sonnen’ when rendering ‘{{ value_json.sonnen }}’
2023-01-07 12:09:19.814 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: ‘homeassistant.util.read_only_dict.ReadOnlyDict object’ has no attribute ‘Pac_total_w’ when rendering ‘{{ states.sensor.json_sonnen.attributes[“Pac_total_w”] }}’
In my configuration it looks like this:
resource: http://192.168.1.208/api/v2/status
value_template: '{{ value_json.sonnen }}'
scan_interval: 1
sensors:
sonnen_stromverbrauch:
friendly_name: 'Power Consumption W'
value_template: '{{ states.sensor.json_sonnen.attributes["Consumption_W"] }}'
unit_of_measurement: watt
sonnen_stromeinspeisung:
friendly_name: 'Electricity Feed In W'
value_template: '{{ states.sensor.json_sonnen.attributes["GridFeedIn_W"] }}'
sonnen_stromerzeugung:
friendly_name: 'Power Generation W'
value_template: '{{ states.sensor.json_sonnen.attributes["Production_W"] }}'
sonnen_stromspeicher:
friendly_name: 'Remaining Charge %'
value_template: '{{ states.sensor.json_sonnen.attributes["USOC"] }}'
sonnen_operatingmode:
friendly_name: 'Mode'
value_template: '{{ states.sensor.json_sonnen.attributes["OperatingMode"] }}'
sonnen_batterycharging:
friendly_name: 'Laddar'
value_template: '{{ states.sensor.json_sonnen.attributes["BatteryCharging"] }}'
sonnen_batterydischarging:
friendly_name: 'Laddar ur'
value_template: '{{ states.sensor.json_sonnen.attributes["BatteryDischarging"] }}'
sonnen_effekt:
friendly_name: 'Effekt'
value_template: '{{ states.sensor.json_sonnen.attributes["Pac_total_w"] }}'
