Hi.
I ran the automatic setup of Google Assistant through Home Assistant Cloud, and everything seems to function fine.
But, I see the following error in the system log ;
ERROR (MainThread) [hassio.addons.addon] Add-on core_google_assistant have wrong options: Missing required option ‘project_id’. Got {‘client_secrets’: ‘google_assistant.json’, ‘project_id’: None, ‘model_id’: None}
I have the following in cloud.yaml, could this be causing the issue?
google_actions:
filter:
include_entities:
- light.xx
- light.xx
- light.xx
- light.xx
include_domains:
- switch
exclude_entities:
- switch.xx
entity_config:
light.xx
aliases:
- xx
room: Living room
I don’t know if it’s related, but config check and reboot is extremely slow. Config check can take 14 minutes.
