Error in the last update HA
Registrador: frontend.js.modern.202511051
Fuente: components/system_log/init.py:331
Ocurrió por primera vez: 08:22:17 (17 ocurrencias)
Última vez registrado: 08:23:28
Failed to format translation for key ‘ui.components.label-picker.no_match’ in language ‘es’. Error: The intl string context variable “term” was not provided to the string “No se han encontrado etiquetas para {term}”
Failed to format translation for key ‘ui.components.device-picker.no_match’ in language ‘es’. Error: The intl string context variable “term” was not provided to the string “No se han encontrado dispositivos para {term}”
Failed to format translation for key ‘ui.components.entity.entity-picker.no_match’ in language ‘es’. Error: The intl string context variable “term” was not provided to the string “No se han encontrado entidades para {term}”
Failed to format translation for key ‘ui.components.area-picker.no_match’ in language ‘es’. Error: The intl string context variable “term” was not provided to the string “No se han encontrado áreas para {term}”
Hello Jose :wave:
Here is a good link helping with your post :point_down:
same here:
2025-11-23 10:32:52.489 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key 'ui.components.statistic-picker.no_match' in language 'de'. Error: The intl string context variable "term" was not provided to the string "Keine Statistiken für {term} gefunden"
The logifle is packed with tons of this message.
This smells to me like a problem with the front end. The people with the error should check if there is already and issue and write one up if there isn’t.
It i reported. Error: The intl string context variable "term" was not provided to the string "No entities found for {term}" · Issue #28048 · home-assistant/frontend · GitHub
This error is occurring in several languages.
In my case, in Brazilian Portuguese.
Same for me but in french… Every second…
[UPDATE]: Just update core from 2025.11.3 to 2025.12.3 and looks like it has been solved !
