I am having trouble compiling the attached code to Esp home, I have checked the code in variuos YAML checkers, all say it is valid. When compiling It comes up with the error :
INFO ESPHome 2026.3.3
INFO Reading configuration /config/esphome/sunroof.yaml...
Failed config
binary_sensor.gpio: [source /config/esphome/sunroof.yaml:133]
The full code is below, any help appreciated.
platform: gpio
pin:
number: GPIO02
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_off: 250ms
on_press:
then:
- if:
condition:
and:
- binary_sensor.is_on: remote_open
- binary_sensor.is_off: remote_close
then:
- switch.turn_on: open_switch
else:
Unable to find action with the name 'then'.
then:
- script.execute: check_inputs
The full code is
switch:
- platform: gpio
pin: GPIO15
restore_mode: RESTORE_DEFAULT_OFF
interlock: &ref_0
- retract_open
- retract_close
- platform: gpio
pin: GPIO14
restore_mode: ALWAYS_OFF
interlock: *ref_0
- platform: gpio
pin: GPIO12
interlock: &ref_1
- rotate_open
- rotate_close
- platform: gpio
pin: GPIO13
interlock: *ref_1
disabled_by_default: false
optimistic: false
assumed_state: false
turn_on_action:
- switch.turn_off: close_switch
- switch.turn_off: open_switch
- switch.turn_off: rotate_open
- switch.turn_off: rotate_close
- switch.turn_off: retract_close
- switch.turn_off: retract_open
- delay: 1s
- switch.turn_off: stop_switch
- logger.log: Stopped
optimistic: false
turn_on_action:
then:
- if:
condition:
and:
- binary_sensor.is_off: remote_open
- binary_sensor.is_on: remote_close
then:
- switch.turn_on: retract_close
- delay: 25s
- switch.turn_on: rotate_close
- delay: 15s
- delay: 500ms
- if:
condition:
- binary_sensor.is_on: rain_close
then:
- delay: 25s
- delay: 15s
- delay: 500ms
optimistic: false
turn_on_action:
then:
- if:
condition:
and:
then:
- switch.turn_on: rotate_open
- delay: 15s
- switch.turn_on: retract_open
- delay: 25s
- delay: 500ms
binary_sensor:
- platform: gpio
pin:
number: GPIO02
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
- if:
condition:
and:
then:
else:
then:
- platform: gpio
pin:
number: GPIO04
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
- if:
condition:
and:
then:
- switch.turn_on: close_switch
else:
then:
- platform: gpio
pin:
number: GPIO05
mode: INPUT_PULLUP
inverted: true
filters:
on_press:
then:
script:
- id: check_inputs
then:
- if:
condition:
and:
then:
- switch.turn_on: stop_switch
