I’m a bit stuck here; any help you can give will be appreciated.
After instal EspHome in Home Assistant I am try to add device Esp32
Hardware Raspberry PI 3+. 1 Mb RAM
I choose “Manual option”
And this is what happens
wnload aaa.yaml
INFO ESPHome 2025.3.3
INFO Reading configuration /config/esphome/aaa.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing aaa (board: esp32dev; framework: arduino; platform: platformio/[email protected])
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.1.4
INFO Installing esphome/AsyncTCP-esphome @ 2.1.4
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.3.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.3.0
Library Manager: Resolving dependencies…
INFO Resolving dependencies…
Library Manager: Installing esphome/noise-c @ 0.1.6
INFO Installing esphome/noise-c @ 0.1.6
Library Manager: Installing esphome/libsodium @ 1.10018.4
INFO Installing esphome/libsodium @ 1.10018.4
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.4
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.3.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.6
Compiling .pioenvs/aaa/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/esphome/ota/ota_esphome.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/ota/ota_backend.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/safe_mode/safe_mode.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/aaa/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/application.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/color.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/component.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/controller.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/log.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/ring_buffer.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/time.cpp.o
Compiling .pioenvs/aaa/src/esphome/core/util.cpp.o
Compiling .pioenvs/aaa/src/main.cpp.o
Building .pioenvs/aaa/bootloader.bin
Creating esp32 image…
Successfully created esp32 image.
Generating partitions .pioenvs/aaa/partitions.bin
Compiling .pioenvs/aaa/libc6a/AsyncTCP-esphome/AsyncTCP.cpp.o
Archiving .pioenvs/aaa/libc6a/libAsyncTCP-esphome.a
Compiling .pioenvs/aaa/lib64d/WiFi/WiFi.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiAP.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiClient.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiGeneric.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiMulti.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiSTA.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiScan.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiServer.cpp.o
Compiling .pioenvs/aaa/lib64d/WiFi/WiFiUdp.cpp.o
Archiving .pioenvs/aaa/lib64d/libWiFi.a
Compiling .pioenvs/aaa/lib01c/FS/FS.cpp.o
Compiling .pioenvs/aaa/lib01c/FS/vfs_api.cpp.o
Archiving .pioenvs/aaa/lib01c/libFS.a
Compiling .pioenvs/aaa/libbc6/Update/HttpsOTAUpdate.cpp.o
Compiling .pioenvs/aaa/libbc6/Update/Updater.cpp.o
Archiving .pioenvs/aaa/libbc6/libUpdate.a
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/aaa/lib403/ESPAsyncWebServer-esphome/WebServer.cpp.o
Archiving .pioenvs/aaa/lib403/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/aaa/lib333/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/aaa/lib333/libDNSServer.a
Compiling .pioenvs/aaa/lib915/ESPmDNS/ESPmDNS.cpp.o
Archiving .pioenvs/aaa/lib915/libESPmDNS.a
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_core/ed25519/core_ed25519.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_core/salsa/ref/core_salsa_ref.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/generichash_blake2.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-avx2.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ref.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-sse41.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ssse3.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_hash/sha512/cp/hash_sha512_cp.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_hash/sha512/hash_sha512.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2-core.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2-encoding.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2-fill-block-avx2.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2-fill-block-avx512f.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2-fill-block-ref.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2-fill-block-ssse3.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/argon2.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/blake2b-long.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/pwhash_argon2i.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_pwhash/argon2/pwhash_argon2id.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_sign/crypto_sign.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_sign/ed25519/ref10/keypair.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_sign/ed25519/ref10/obsolete.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_sign/ed25519/ref10/open.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_sign/ed25519/ref10/sign.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_sign/ed25519/sign_ed25519.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/salsa20/ref/salsa20_ref.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/salsa20/stream_salsa20.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6-asm.S.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-avx2.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-sse2.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/crypto_verify/sodium/verify.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/randombytes/internal/randombytes_internal_random.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/randombytes/randombytes.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/randombytes/sysrandom/randombytes_sysrandom.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/sodium/codecs.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/sodium/core.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/sodium/runtime.c.o
Compiling .pioenvs/aaa/lib77c/libsodium/sodium/utils.c.o
Archiving .pioenvs/aaa/lib77c/libsodium.a
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/ref/dh-curve25519.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/ref/hash-blake2b.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/ref/hash-sha256.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/sodium/dh-curve25519.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/sodium/hash-blake2b.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/backend/sodium/hash-sha256.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/blake2/blake2b.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/blake2/blake2s.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/chacha/chacha.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/errors.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/internal.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/names.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/patterns.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/randstate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/signstate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/aaa/lib3ae/noise-c/protocol/util.c.o
Archiving .pioenvs/aaa/lib3ae/libnoise-c.a
Compiling .pioenvs/aaa/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/HWCDC.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/IPv6Address.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/StreamString.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/USB.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/USBCDC.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/USBMSC.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-time.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pioenvs/aaa/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pioenvs/aaa/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pioenvs/aaa/FrameworkArduino/libb64/cdecode.c.o
Compiling .pioenvs/aaa/FrameworkArduino/libb64/cencode.c.o
Compiling .pioenvs/aaa/FrameworkArduino/main.cpp.o
Compiling .pioenvs/aaa/FrameworkArduino/stdlib_noniso.c.o
Compiling .pioenvs/aaa/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/aaa/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/aaa/libFrameworkArduino.a
Linking .pioenvs/aaa/firmware.elf
collect2: fatal error: ld terminated with signal 9 [Killed]
compilation terminated.
[u]* [.pioenvs/aaa/firmware.elf] Error 1[/u]**
========================= [FAILED] Took 685.75 seconds =========================./>
