Error installing Home Assistant on mini PC
I’m attempting to perform the initial installation of Home Assistant, but I’m encountering the following error log.
Could someone please assist me in resolving this issue?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[19:50:33] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[19:50:33] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
2025-04-11 19:50:35.928 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-04-11 19:50:36.112 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: generic-x86-64
2025-04-11 21:50:36.138 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2025.04.0
2025-04-11 21:50:36.139 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2025-04-11 21:50:36.487 INFO (SyncWorker_1) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2024.06.0']
2025-04-11 21:50:38.041 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-04-11 21:50:38.057 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-11 21:50:38.061 INFO (MainThread) [__main__] Setting up Supervisor
2025-04-11 21:50:38.496 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-04-11 21:50:38.711 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-04-11 21:50:38.714 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-04-11 21:50:38.715 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-04-11 21:50:38.716 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-04-11 21:50:38.717 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-04-11 21:50:38.718 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-04-11 21:50:38.719 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-04-11 21:50:38.719 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-04-11 21:50:38.720 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-04-11 21:50:38.721 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-04-11 21:50:38.851 ERROR (MainThread) [supervisor.dbus.agent] Can't load OS Agent dbus interface io.hass.os /io/hass/os/Config/Swap: D-Bus object /io/hass/os/Config/Swap is not usable, introspection is missing required properties interface
2025-04-11 21:50:39.205 INFO (MainThread) [supervisor.host.services] Updating service information
2025-04-11 21:50:39.216 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-04-11 21:50:39.473 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-04-11 21:50:39.715 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2025-04-11 21:50:39.757 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-04-11 21:50:39.758 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-04-11 21:50:40.271 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.05.0
2025-04-11 21:50:40.406 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0
2025-04-11 21:50:40.484 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-04-11 21:50:40.531 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
2025-04-11 21:50:40.642 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
2025-04-11 21:50:40.726 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
2025-04-11 21:50:40.797 INFO (MainThread) [supervisor.plugins.manager] Plugin cli is not up-to-date, latest version 2025.02.0, updating
2025-04-11 21:50:40.810 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/amd64-hassio-cli:2024.05.0 to ghcr.io/home-assistant/amd64-hassio-cli:2025.02.0
2025-04-11 21:50:40.811 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-cli with tag 2025.02.0.
2025-04-11 21:50:47.498 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping hassio_cli application
2025-04-11 21:50:51.959 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_cli application
2025-04-11 21:50:52.217 INFO (SyncWorker_1) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-cli:2024.05.0']
2025-04-11 21:50:52.392 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2025-04-11 21:50:53.443 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2025.02.0 - 172.30.32.5
2025-04-11 21:50:53.445 INFO (MainThread) [supervisor.plugins.manager] Plugin dns is not up-to-date, latest version 2025.02.0, updating
2025-04-11 21:50:53.450 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/amd64-hassio-dns:2024.04.0 to ghcr.io/home-assistant/amd64-hassio-dns:2025.02.0
2025-04-11 21:50:53.451 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-dns with tag 2025.02.0.
2025-04-11 21:51:04.363 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping hassio_dns application
2025-04-11 21:51:08.178 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_dns application
2025-04-11 21:51:08.337 INFO (SyncWorker_1) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-dns:2024.04.0']
2025-04-11 21:51:08.863 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2025-04-11 21:51:09.865 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2025.02.0 - 172.30.32.3
2025-04-11 21:51:09.867 INFO (MainThread) [supervisor.plugins.manager] Plugin audio is not up-to-date, latest version 2025.02.0, updating
2025-04-11 21:51:09.873 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/amd64-hassio-audio:2023.12.0 to ghcr.io/home-assistant/amd64-hassio-audio:2025.02.0
2025-04-11 21:51:09.875 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-audio with tag 2025.02.0.
2025-04-11 21:51:57.092 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping hassio_audio application
2025-04-11 21:52:01.251 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_audio application
2025-04-11 21:52:01.500 INFO (SyncWorker_1) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-audio:2023.12.0']
2025-04-11 21:52:02.396 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2025-04-11 21:52:03.604 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2025.02.0 - 172.30.32.4
2025-04-11 21:52:03.609 INFO (MainThread) [supervisor.plugins.manager] Plugin observer is not up-to-date, latest version 2025.02.0, updating
2025-04-11 21:52:03.620 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/amd64-hassio-observer:2023.06.0 to ghcr.io/home-assistant/amd64-hassio-observer:2025.02.0
2025-04-11 21:52:03.621 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-observer with tag 2025.02.0.
2025-04-11 21:52:09.689 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping hassio_observer application
2025-04-11 21:52:10.622 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_observer application
2025-04-11 21:52:10.825 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-observer:2023.06.0']
2025-04-11 21:52:10.967 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
2025-04-11 21:52:12.007 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2025.02.0 - 172.30.32.6
2025-04-11 21:52:12.009 INFO (MainThread) [supervisor.plugins.manager] Plugin multicast is not up-to-date, latest version 2025.02.0, updating
2025-04-11 21:52:12.018 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/amd64-hassio-multicast:2024.03.0 to ghcr.io/home-assistant/amd64-hassio-multicast:2025.02.0
2025-04-11 21:52:12.019 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-multicast with tag 2025.02.0.
2025-04-11 21:52:14.914 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping hassio_multicast application
2025-04-11 21:52:18.312 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_multicast application
2025-04-11 21:52:18.462 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-multicast:2024.03.0']
2025-04-11 21:52:18.823 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2025-04-11 21:52:19.254 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2025.02.0 - Host
2025-04-11 21:52:19.260 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2025-04-11 21:52:19.269 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
2025-04-11 21:52:19.291 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2025-04-11 21:52:19.353 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.4 / BootSlot A
2025-04-11 21:52:19.359 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2025-04-11 21:52:19.360 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2025-04-11 21:52:19.361 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2025-04-11 21:52:19.367 INFO (MainThread) [supervisor.store.git] Cloning add-on /data/addons/git/d5369777 repository from https://github.com/music-assistant/home-assistant-addon
2025-04-11 21:52:21.506 INFO (MainThread) [supervisor.store] Loading add-ons from store: 82 all - 82 new - 0 remove
2025-04-11 21:52:21.626 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-04-11 21:52:21.739 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2025-04-11 21:52:21.740 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-04-11 21:52:21.740 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-04-11 21:52:21.741 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-04-11 21:52:21.742 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-04-11 21:52:21.743 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-04-11 21:52:21.744 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-04-11 21:52:21.744 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-04-11 21:52:21.747 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-04-11 21:52:21.748 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-04-11 21:52:21.750 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-11 21:52:21.751 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-04-11 21:52:21.752 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-04-11 21:52:21.753 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-11 21:52:21.754 INFO (MainThread) [__main__] Running Supervisor
2025-04-11 21:52:22.140 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-04-11 21:52:22.194 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2025-04-11 21:52:22.292 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2025-04-11 21:52:22.293 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2025-04-11 21:52:22.313 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2025-04-11 21:52:22.313 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2025-04-11 21:52:22.333 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-04-11 21:52:22.336 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2025-04-11 21:52:22.337 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2025.4.1
2025-04-11 21:52:22.339 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2025.4.1.
2025-04-11 21:52:22.340 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-04-11 21:52:22.343 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-04-11 21:52:22.361 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-04-11 21:52:22.361 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-04-11 21:52:22.362 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-04-11 21:52:22.363 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-04-11 21:52:22.364 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-04-11 21:52:22.365 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-04-11 21:52:22.385 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-04-11 21:52:22.446 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-04-11 21:52:22.590 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-04-11 21:52:22.591 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2025-04-11 21:52:22.592 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2025-04-11 21:52:22.593 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-04-11 21:52:22.595 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-04-11 21:52:22.616 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-04-11 21:52:22.618 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-04-11 21:52:22.618 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-04-11 21:52:22.618 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-04-11 21:52:22.993 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-11 21:52:22.993 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-04-11 21:52:22.994 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-04-11 21:52:23.190 INFO (MainThread) [supervisor.host.services] Updating service information
2025-04-11 21:52:23.201 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-04-11 21:52:23.667 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-04-11 21:52:23.691 INFO (MainThread) [supervisor.host.manager] Host information reload completed
There’s only 1 line which reports an error. The rest of the log, both before and after the error, seems fine.
What exactly is your issue? Please tell us more if you want us to help you
I installed the HA image on my micro SD (raspberry 3) and I have the same erreor message :
[supervisor.dbus.agent] Can’t load OS Agent dbus interface io.hass.os /io/hass/os/Config/Swap: D-Bus object /io/hass/os/Config/Swap is not usable, introspection is missing required properties interface
Could you help us please ?
I have this error as well. Maybe it doesn’t matter but it would be good to know why it is there?
2025-06-03 13:01:18.045 INFO (MainThread) [main] Initializing Supervisor setup
2025-06-03 23:01:18.127 INFO (MainThread) [main] Setting up Supervisor
2025-06-03 23:01:18.263 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
2025-06-03 23:01:18.288 ERROR (MainThread) [supervisor.dbus.agent] Can’t load OS Agent dbus interface io.hass.os /io/hass/os/Config/Swap: D-Bus object /io/hass/os/Config/Swap is not usable, introspection is missing required properties interface
2025-06-03 23:01:18.376 WARNING (SyncWorker_2) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
2025-06-03 23:01:23.458 INFO (MainThread) [main] Running Supervisor
Ok, I fixed my issue.
Just needed to install the latest os-agent on my supervised installation.
The ERROR (MainThread) [supervisor.dbus.agent] Can’t load OS Agent dbus interface io.hass.os /io/hass/os/Config/Swap: D-Bus object /io/hass/os/Config/Swap is not usable, introspection is missing required properties interface is then gone.
