Error installing Home Assistant: please help
Hey i installed HA on my Pi.
The following Error apears. I had to install an older HA Version due a USB install bug.
25-07-03 20:01:21 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
25-07-03 20:01:21 INFO (MainThread) [__main__] Setting up Supervisor
25-07-03 20:01:21 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
25-07-03 20:01:21 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
25-07-03 20:01:21 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
25-07-03 20:01:22 INFO (MainThread) [supervisor.host.services] Updating service information
25-07-03 20:01:22 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
25-07-03 20:01:22 INFO (MainThread) [supervisor.host.network] Updating local network information
25-07-03 20:01:22 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
25-07-03 22:01:22 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
25-07-03 22:01:22 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
25-07-03 22:01:23 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.06.0
25-07-03 22:01:23 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
25-07-03 22:01:23 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
25-07-03 22:01:24 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.06.0 - 172.30.32.5
25-07-03 22:01:24 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
25-07-03 22:01:24 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
25-07-03 22:01:24 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
25-07-03 22:01:28 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
25-07-03 22:01:28 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
25-07-03 22:01:28 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.06.0
25-07-03 22:01:29 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
25-07-03 22:01:30 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
25-07-03 22:02:31 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.06.0 - 172.30.32.4
25-07-03 22:02:31 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
25-07-03 22:02:31 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
25-07-03 22:02:31 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
25-07-03 22:02:31 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
25-07-03 22:02:32 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
25-07-03 22:02:32 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
25-07-03 22:02:32 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
25-07-03 22:02:32 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
25-07-03 22:02:32 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
25-07-03 22:02:32 ERROR (MainThread) [supervisor.homeassistant.core] Watchdog restart of Home Assistant failed!
25-07-03 22:02:32 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
25-07-03 22:02:32 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
25-07-03 22:02:33 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/configurator/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][2]. Got 'homeassistant_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/samba/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][3]. Got 'homeassistant_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
25-07-03 22:02:33 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: expected string or buffer @ data['map'][0]. Got {'type': 'addon_config', 'read_only': False}
25-07-03 22:02:33 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/whisper/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/zwave_js/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'homeassistant_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.yaml: expected string or buffer @ data['map'][0]. Got {'type': 'addons', 'read_only': False}
expected string or buffer @ data['map'][1]. Got {'type': 'all_addon_configs', 'read_only': False}
expected string or buffer @ data['map'][2]. Got {'type': 'backup', 'read_only': False}
expected string or buffer @ data['map'][3]. Got {'type': 'homeassistant_config', 'read_only': False, 'path': '/config'}
expected string or buffer @ data['map'][4]. Got {'type': 'media', 'read_only': False}
expected string or buffer @ data['map'][5]. Got {'type': 'share', 'read_only': False}
expected string or buffer @ data['map'][6]. Got {'type': 'ssl', 'read_only': False}
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/overseerr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/emqx/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/radarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sabnzbd/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/grafana/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/prowlarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/readarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/lidarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/whisparr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/log-viewer/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config'
25-07-03 22:02:33 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/nginxproxymanager/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.addons.validate] Add-on lists the following unknown services for discovery: uptime_kuma. Please report this to the maintainer of Uptime Kuma
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/bazarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sonarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
25-07-03 22:02:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
25-07-03 22:02:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
25-07-03 22:02:34 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/configurator/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'all_addon_configs:rw'
25-07-03 22:02:34 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/samba/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
25-07-03 22:02:34 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
25-07-03 22:02:34 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: expected string or buffer @ data['map'][0]. Got {'type': 'addon_config', 'read_only': False}
25-07-03 22:02:34 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/whisper/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/zwave_js/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.yaml: expected string or buffer @ data['map'][0]. Got {'type': 'addons', 'read_only': False}
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/overseerr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/emqx/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/radarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sabnzbd/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][1]. Got 'all_addon_configs:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/grafana/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/prowlarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/readarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/lidarr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/whisparr/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/log-viewer/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'homeassistant_config'
25-07-03 22:02:34 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/nginxproxymanager/config.yaml: does not match regular expression ^(config|ssl|addons|backup|share|media)(?::(rw|ro))?$ @ data['map'][0]. Got 'addon_config:rw'
25-07-03 22:02:34 INFO (MainThread) [supervisor.store] Loading add-ons from store: 51 all - 51 new - 0 remove
25-07-03 22:02:34 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
25-07-03 22:02:34 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
25-07-03 22:02:34 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
25-07-03 22:02:34 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
25-07-03 22:02:34 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
25-07-03 22:02:34 INFO (MainThread) [supervisor.resolution.check] System checks complete
25-07-03 22:02:34 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
25-07-03 22:02:34 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
25-07-03 22:02:34 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
25-07-03 22:02:34 INFO (MainThread) [__main__] Running Supervisor
25-07-03 22:02:34 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
25-07-03 22:02:34 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
25-07-03 22:02:34 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
25-07-03 22:02:35 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2025.06.2
25-07-03 22:02:35 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2025.06.2.
25-07-03 22:02:46 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2/json: Not Found ("No such image: ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2")
25-07-03 22:02:46 INFO (MainThread) [supervisor.resolution.module] Create new issue update_failed - supervisor / None
25-07-03 22:02:46 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2/json: Not Found ("No such image: ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2")
25-07-03 22:02:46 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
25-07-03 22:02:46 INFO (MainThread) [supervisor.addons] Phase 'initialize' starting 0 add-ons
25-07-03 22:02:47 INFO (MainThread) [supervisor.addons] Phase 'system' starting 0 add-ons
25-07-03 22:02:47 INFO (MainThread) [supervisor.addons] Phase 'services' starting 0 add-ons
25-07-03 22:02:47 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
25-07-03 22:02:47 INFO (MainThread) [supervisor.addons] Phase 'application' starting 0 add-ons
25-07-03 22:02:47 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
25-07-03 22:02:47 INFO (MainThread) [supervisor.core] Supervisor is up and running
25-07-03 22:02:47 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
25-07-03 22:02:47 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.7.0
25-07-03 22:02:47 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2025.7.0.
25-07-03 22:02:47 INFO (MainThread) [supervisor.host.info] Updating local host information
25-07-03 22:02:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
25-07-03 22:02:47 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
25-07-03 22:02:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
25-07-03 22:02:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
25-07-03 22:02:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
25-07-03 22:02:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
25-07-03 22:02:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.check] System checks complete
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
25-07-03 22:02:49 INFO (MainThread) [supervisor.host.services] Updating service information
25-07-03 22:02:49 INFO (MainThread) [supervisor.host.network] Updating local network information
25-07-03 22:02:49 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
25-07-03 22:02:49 INFO (MainThread) [supervisor.host.manager] Host information reload completed
25-07-03 22:02:49 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
25-07-03 22:02:49 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
Can somebody help me please :slight_smile:
ERROR: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.06.2
he update attempt failed due to a 404 error (image not found). The Supervisor tried pulling a non-existent or unpublished Docker image.
WARNING: Watchdog found Home Assistant failed, restarting...
ERROR: Watchdog restart of Home Assistant failed!
is indicates the Home Assistant Core container (landingpage) couldn’t boot or crashed immediately.
WARNING: Can't read config.yaml: does not match regular expression...
These warnings show your add-ons have invalid map: fields in their config.yaml (such as 'addon_config:rw'), which no longer conform to the Supervisor’s expected format. The accepted values must strictly be:
config:rw
ssl:rw
addons:rw
backup:rw
share:rw
media:rw
This indicates some add-ons are using structured mapping (objects) instead of the required string format, like:
map:
  - config:rw  # ✅ Valid
  - {type: config, read_only: false}  # ❌ Invalid
edit manually config.yaml
from
map:
  - addon_config:rw
  - homeassistant_config:rw
to
map:
  - config:rw
SSH into the host.
Fix the add-on config.yaml under /data/addons/config.yaml.
Restart Supervisor:
ha supervisor restart
Manually install Home Assistant Core if not pulled correctly:
ha core update --version 2025.7.0
hope this can help you
