I decided to update my existing virtual environment from Python 3.8 (where I now get I warning message about using an old Python version) so I upgraded to Python 3.10, but installation of Home Assistant fails when building the wheel for homeassistant-pyozw
Collecting homeassistant-pyozw
Using cached homeassistant_pyozw-0.1.10.zip (147 kB)
Preparing metadata (setup.py) ... done
Requirement already satisfied: six in ./lib/python3.10/site-packages (from homeassistant-pyozw) (1.16.0)
Requirement already satisfied: PyDispatcher>=2.0.5 in ./lib/python3.10/site-packages (from homeassistant-pyozw) (2.0.5)
Building wheels for collected packages: homeassistant-pyozw
Building wheel for homeassistant-pyozw (setup.py) ...
/usr/local/include/python3.10/object.h:133:58: error: lvalue required as decrement operand
#define Py_REFCNT(ob) _Py_REFCNT(_PyObject_CAST_CONST(ob))
error: command '/usr/bin/gcc' failed with exit code 1
ERROR: Failed building wheel for homeassistant-pyozw
Works fine with Python 3.8. Any clues? RPI packages are up to date.
