Error installing Sunricher Wall Switches
Hi there,
Just started with Home Assistant (old Homey user) and started installing devices. So far, almost good.
I’ve had a problem with the installation of the sunricher wall switches (2, 4 and 8 knobs), with battery, zigbee variant.
It does find the switch, but only shows battery status/power. It does nog regognise any knobs/switches. Should’nt this have to be at identities?
Please help, greetings, Michiel
Same here…
First of all, it would help if you told what ZigBee integration you are using : zigbee2mqtt, ZHA or deconz.
Second: ZigBee switches normally don’t create entities to switch, you have to listen to events.
Figured it out. Im kind of new to zigbee, so i guess this is basic stuff. I thought the buttons would show up as entities. Under developer tols>events, i listened to zha_event, then pressed the buttons on the wall swith. The events did register.
So, i guess i just need to create automation that triggers on events instead of entity states.
Hello Malnes,
is it possible to share a blueprint for this switch?
I’m at the same point to figure the integration out…
BR Ronny
