Error Log for my Home Assistant
I am using the unraid docker and getting this list of errors in my log file. Not sure what I am doing wrong or why i am getting them. The ones I am most concerned about because it seems to be affecting my setup are asuswrt and honeywell
2018-04-11 09:02:55 WARNING (zeroconf-Engine) [zeroconf] Choked at offset 106 while unpacking b'\x00\x00\x84\x00\x00\x00\x00\x04\x00\x00\x00\x01\x00\x00\x0c\x00\x01\x00\x00\x01,\x00\x04\x02\x880\x00\x02\x880\x00\x00!\x80\x01\x00\x00\x01,\x00\x0b\xf3\x08\x80\xef\xf3\t\x03\x81rF\x00\x07MyQ-BD5\x05local\x00\x00\x01\x80\x01\x00\x00\x01,\x00\x04\xc0\xa8\x01\xe6\x02\x880\x00\x00/\x80\x01\x00\x00\x01,\x00\x0b\x02\x880\x00\x00\x05\x00\x08\x00\x00@'
2018-04-11 09:02:55 WARNING (zeroconf-Engine) [zeroconf] Exception occurred:
  File "/usr/local/lib/python3.6/site-packages/zeroconf.py", line 645, in __init__
    self.read_others()
  File "/usr/local/lib/python3.6/site-packages/zeroconf.py", line 698, in read_others
    domain = self.read_name()
  File "/usr/local/lib/python3.6/site-packages/zeroconf.py", line 752, in read_name
    length = self.data[off]
IndexError: index out of range
2018-04-11 09:02:59 WARNING (MainThread) [homeassistant.helpers.condition] Value cannot be processed as a number:
2018-04-11 09:04:13 ERROR (Thread-5) [pychromecast.socket_client] Error reading from socket.
2018-04-11 09:04:13 WARNING (Thread-5) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-11 09:04:13 ERROR (Thread-5) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-11 09:07:57 ERROR (SyncWorker_1) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 09:23:11 ERROR (Thread-3) [pychromecast.socket_client] Error reading from socket.
2018-04-11 09:23:11 WARNING (Thread-3) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-11 09:23:11 ERROR (Thread-3) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-11 09:35:52 ERROR (Thread-5) [pychromecast.socket_client] Error reading from socket.
2018-04-11 09:35:52 WARNING (Thread-5) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-11 09:35:52 ERROR (Thread-5) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-11 10:19:20 ERROR (Thread-5) [pychromecast.socket_client] Error reading from socket.
2018-04-11 10:19:20 WARNING (Thread-5) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-11 10:19:20 ERROR (Thread-5) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-11 10:23:07 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:25:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:27:09 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:29:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:31:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:33:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:35:17 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:37:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:39:20 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:41:22 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:43:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:45:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:47:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:49:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:51:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:53:17 ERROR (SyncWorker_3) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 10:53:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:55:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:57:35 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 10:59:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:01:38 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:03:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:05:42 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:07:44 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:08:20 ERROR (SyncWorker_14) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 11:09:46 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:11:47 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:13:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:15:51 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:17:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:18:22 ERROR (SyncWorker_3) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 11:19:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:21:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:23:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:26:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:28:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:30:05 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:32:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:34:07 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:36:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:38:09 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:38:26 ERROR (SyncWorker_35) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 11:40:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:42:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:44:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:46:16 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:48:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:48:28 ERROR (SyncWorker_5) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 11:50:19 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:52:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:54:22 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:56:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:58:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 11:58:29 ERROR (SyncWorker_0) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 12:00:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:02:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:04:30 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:06:32 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:08:31 ERROR (SyncWorker_38) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 12:08:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:10:34 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:12:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:14:38 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:16:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:18:42 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:20:43 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:22:44 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:24:46 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:26:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:28:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:30:50 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:32:52 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:34:54 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:36:56 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:38:58 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:40:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:43:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:45:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:47:04 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:49:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:51:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:53:10 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:55:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:57:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 12:58:40 ERROR (SyncWorker_11) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 12:59:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:01:17 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:03:19 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:05:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:07:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:08:49 ERROR (SyncWorker_21) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-04-11 13:09:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:11:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:13:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:15:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:17:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:18:45 ERROR (SyncWorker_4) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-11 13:19:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:21:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:23:35 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:25:37 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:27:39 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:29:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:30:28 ERROR (Thread-3) [pychromecast.socket_client] Error reading from socket.
2018-04-11 13:30:28 WARNING (Thread-3) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-11 13:30:28 ERROR (Thread-3) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-11 13:31:42 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:33:44 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:35:45 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:37:47 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:39:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:41:51 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:43:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:45:54 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:47:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:49:56 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:51:58 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:53:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:56:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 13:58:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:00:05 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:01:52 ERROR (Thread-5) [pychromecast.socket_client] Error reading from socket.
2018-04-11 14:01:52 WARNING (Thread-5) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-11 14:01:52 ERROR (Thread-5) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-11 14:02:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:04:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:06:10 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:08:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:10:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:12:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:14:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:16:16 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:18:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:20:20 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:22:22 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:24:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:26:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:28:26 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:30:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:32:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:34:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:36:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:38:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-11 14:39:02 ERROR (SyncWorker_31) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
Is anyone else having similar problems or does anyone have an idea on what might be going on here. This was with 0.66.1 so I rolled back to 0.65.6 hoping maybe that would help but I seem to get the errors there as well.
This seems to be failing every 10 minutes for my honeywell thermostat which is how often I have it getting an update. It seemed to work for half the day but not it doesn’t seem to be. Not sure what to do. I can changed the temp manually within home assistant but when i go to use automations it seems to fail.
2018-04-12 14:09:48 ERROR (SyncWorker_31) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 14:19:48 ERROR (SyncWorker_5) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 14:29:49 ERROR (SyncWorker_30) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 14:39:51 ERROR (SyncWorker_11) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 14:47:50 ERROR (Thread-5) [pychromecast.socket_client] Error reading from socket.
2018-04-12 14:47:50 WARNING (Thread-5) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-04-12 14:49:53 ERROR (SyncWorker_32) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 14:59:55 ERROR (SyncWorker_24) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 15:09:57 ERROR (SyncWorker_33) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed
Starting last night I am now gettting a device tracker error every minute which is how the timer interval of my Asus Router scan.
2018-04-12 23:07:51 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:09:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:11:54 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:13:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:15:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:17:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:20:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:22:02 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:24:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:26:04 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:28:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:30:07 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:32:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:34:09 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:36:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:38:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:40:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:41:47 ERROR (SyncWorker_22) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-12 23:42:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:44:17 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:46:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:48:20 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:50:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:52:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:54:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:56:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-12 23:58:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:00:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:01:51 ERROR (SyncWorker_35) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-13 00:02:30 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:04:32 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:06:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:08:35 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:10:37 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:11:53 ERROR (SyncWorker_36) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-13 00:12:38 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:14:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:16:41 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:18:43 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:20:45 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:21:53 ERROR (SyncWorker_19) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-13 00:22:46 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:24:47 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:26:48 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:28:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:30:51 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:32:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:34:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:36:56 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:38:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:40:58 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:41:57 ERROR (SyncWorker_31) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-13 00:42:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:45:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:47:02 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:49:04 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:51:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:53:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:55:10 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:57:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 00:59:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:00:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.pws_temp_f is taking over 10 seconds
2018-04-13 01:00:12 ERROR (MainThread) [homeassistant.components.sensor.wunderground] Error fetching WUnderground data: TimeoutError()
2018-04-13 01:01:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:02:01 ERROR (SyncWorker_31) [homeassistant.components.climate.honeywell] SomeComfort update failed, Retrying - Error: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
2018-04-13 01:03:16 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:05:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:07:20 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:09:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:11:22 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:13:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:15:26 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:17:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:19:30 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:21:32 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:23:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:25:34 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:27:35 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:29:37 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:31:39 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:33:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:35:42 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:37:43 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:39:44 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:41:46 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:43:47 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:45:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:47:50 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:49:52 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:51:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:53:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:55:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 01:57:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:00:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:02:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:04:05 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:06:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:08:07 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:10:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:12:10 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:14:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:16:12 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:18:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:20:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:22:16 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:24:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:26:19 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:28:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:30:22 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:32:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:34:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:36:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:38:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:40:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:42:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:44:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:46:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:48:34 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:50:35 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:52:37 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:54:38 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:56:39 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 02:58:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:00:42 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:02:43 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:04:45 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:06:46 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:08:47 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:10:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:12:50 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:14:52 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:16:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:18:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:20:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:22:58 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:24:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:27:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:29:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:31:04 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:33:06 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:35:07 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:37:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:39:10 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:41:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:43:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:45:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:47:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:49:16 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:51:17 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:53:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:55:20 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:57:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 03:59:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:01:24 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:03:26 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:05:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:07:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:09:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:11:32 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:13:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:15:34 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:17:36 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
2018-04-13 04:19:38 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:01:00
I had to shorten the log but it continued all night.
