My error log keeps filling up with errors that has been coming a lot since about 0.35 ish. Does anyone know what the cause might be?
2017-09-01 22:09:22 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
File “/usr/lib/python3.4/asyncio/selector_events.py”, line 582, in _read_ready
data = self._sock.recv(self.max_size)
OSError: [Errno 113] No route to host
2017-09-01 22:09:22 ERROR (MainThread) [aiohttp.server] Error handling request
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/websocket_api.py”, line 326, in handle
msg = yield from wsock.receive_json()
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_ws.py”, line 328, in receive_json
data = yield from self.receive_str(timeout=timeout)
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_ws.py”, line 310, in receive_str
msg = yield from self.receive(timeout)
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_ws.py”, line 273, in receive
msg = yield from self._reader.read()
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/streams.py”, line 627, in read
return (yield from super().read())
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/streams.py”, line 509, in read
yield from self._waiter
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 269, in result
raise CancelledError
concurrent.futures._base.CancelledError
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web_protocol.py”, line 422, in start
resp = yield from self._request_handler(request)
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/web.py”, line 306, in _handle
resp = yield from handler(request)
File “/usr/lib/python3.4/asyncio/coroutines.py”, line 143, in coro
res = yield from res
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/ban.py”, line 58, in ban_middleware_handler
return (yield from handler(request))
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 424, in handle
result = yield from result
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/websocket_api.py”, line 388, in handle
yield from self._writer_task
File “/usr/lib/python3.4/asyncio/futures.py”, line 390, in iter
return self.result() # May raise too.
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/asyncio/tasks.py”, line 233, in _step
result = coro.throw(exc)
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/websocket_api.py”, line 238, in _writer
yield from self.wsock.send_json(message, dumps=JSON_DUMP)
File “/srv/homeassistant/lib/python3.4/site-packages/aiohttp/http_writer.py”, line 128, in drain
yield from self._protocol._drain_helper()
File “/usr/lib/python3.4/asyncio/streams.py”, line 197, in _drain_helper
yield from waiter
