Error logged when I enter the Integrations page
Hi, whenever I go into the Integrations page, I get the following error twice in a row in home-assistant.log. It’s all in one line with %dd replacing the non alphabet/digit characters as such:
2020-02-10 19:34:42 ERROR (MainThread) [frontend.js.latest.202001301] data:text/javascript;charset=utf-8,%2F*!%20For%20license%20information%20please%20see%20scripts.js.LICENSE%20*%2F%0A!function....
But I exploded it to make it easier to see and hopefully someone can/will pinpoint the problem:
2020-02-10 19:34:42 ERROR (MainThread) [frontend.js.latest.202001301] data:text/javascript;charset=utf-8,/*! For license information please see scripts.js.LICENSE */
!function(t){var e={};function s(i){if(e[i])return e[i].exports;var n=e[i]={i:i,l:!1,exports:{}};return t[i].call(n.exports,n,n.exports,s),n.l=!0,n.exports}s.m=t,s.c=e,s.d=function(t,e,i){s.o(t,e)||Object.defineProperty(t,e,{configurable:!1,enumerable:!0,get:i})},s.r=function(t){Object.defineProperty(t,"__esModule",{value:!0})},s.n=function(t){var e=t&&t.__esModule?function(){return t.default}:function(){return t};return s.d(e,"a",e),e},s.o=function(t,e){return Object.prototype.hasOwnProperty.call(t,e)},s.p="",s(s.s=0)}([function(t,e,s){"use strict";function i(t,e,s,i=!1){t._themes||(t._themes={});let n=e.default_theme;("default"===s||s&&e.themes[s])&&(n=s);const a={...t._themes};if("default"!==n){const s=e.themes[n];Object.keys(s).forEach(e=>{const i="--"+e;t._themes[i]="",a[i]=s[e]})}if(t.updateStyles?t.updateStyles(a):window.ShadyCSS&&window.ShadyCSS.styleSubtree(t,a),!i)return;const o=document.querySelector("meta[name=theme-color]");if(o){o.hasAttribute("default-content")||o.setAttribute("default-content",o.getAttribute("content"));const t=a["--primary-color"]||o.getAttribute("default-content");o.setAttribute("content",t)}}function n(t){return t.substr(0,t.indexOf("."))}function a(t){return n(t.entity_id)}function o(t,e,s){const i=t;let n;i.lastChild&&i.lastChild.tagName===e?n=i.lastChild:(i.lastChild&&i.removeChild(i.lastChild),n=document.createElement(e.toLowerCase())),n.setProperties?n.setProperties(s):Object.keys(s).forEach(t=>{n[t]=s[t]}),null===n.parentNode&&i.appendChild(n)}s.r(e);const r=(t,e)=>0!=(t.attributes.supported_features&e),l=["climate","cover","configurator","input_select","input_number","input_text","lock","media_player","scene","script","timer","vacuum","water_heater","weblink"];new Set(["fan","input_boolean","light","switch","group","automation"]);const c=new WeakMap,d=t=>"function"==typeof t&&c.has(t),u=void 0!==window.customElements&&void 0!==window.customElements.polyfillWrapFlushCallback,h=(t,e,s=null)=>{let i=e;for(;i!==s;){const e=i.nextSibling;t.removeChild(i),i=e}},p={},m={},g=`{{lit-${String(Math.random()).slice(2)}}}`,y=`\x3c!--${g}--\x3e`,b=new RegExp(`${g}|${y}`),_="$lit$";class f{constructor(t,e){this.parts=[],this.element=e;let s=-1,i=0;const n=[],a=e=>{const o=e.content,r=document.createTreeWalker(o,133,null,!1);let l=0;for(;r.nextNode();){s++;const e=r.currentNode;if(1===e.nodeType){if(e.hasAttributes()){const n=e.attributes;let a=0;for(let t=0;t<n.length;t++)n[t].value.indexOf(g)>=0&&a++;for(;a-- >0;){const n=t.strings[i],a=S.exec(n)[2],o=a.toLowerCase()+_,r=e.getAttribute(o).split(b);this.parts.push({type:"attribute",index:s,name:a,strings:r}),e.removeAttribute(o),i+=r.length-1}}"TEMPLATE"===e.tagName&&a(e)}else if(3===e.nodeType){const t=e.data;if(t.indexOf(g)>=0){const a=e.parentNode,o=t.split(b),r=o.length-1;for(let t=0;t<r;t++)a.insertBefore(""===o[t]?v():document.createTextNode(o[t]),e),this.parts.push({type:"node",index:++s});""===o[r]?(a.insertBefore(v(),e),n.push(e)):e.data=o[r],i+=r}}else if(8===e.nodeType)if(e.data===g){const t=e.parentNode;null!==e.previousSibling&&s!==l||(s++,t.insertBefore(v(),e)),l=s,this.parts.push({type:"node",index:s}),null===e.nextSibling?e.data="":(n.push(e),s--),i++}else{let t=-1;for(;-1!==(t=e.data.indexOf(g,t+1));)this.parts.push({type:"node",index:-1})}}};a(e);for(const t of n)t.parentNode.removeChild(t)}}const w=t=>-1!==t.index,v=()=>document.createComment(""),S=/([ \x09\x0a\x0c\x0d])([^\0-\x1F\x7F-\x9F \x09\x0a\x0c\x0d"'>=/]+)([ \x09\x0a\x0c\x0d]*=[ \x09\x0a\x0c\x0d]*(?:[^ \x09\x0a\x0c\x0d"'`<>=]*|"[^"]*|'[^']*))$/;class C{constructor(t,e,s){this._parts=[],this.template=t,this.processor=e,this.options=s}update(t){let e=0;for(const s of this._parts)void 0!==s&&s.setValue(t[e]),e++;for(const t of this._parts)void 0!==t&&t.commit()}_clone(){const t=u?this.template.element.content.cloneNode(!0):document.importNode(this.template.element.content,!0),e=this.template.parts;let s=0,i=0;const n=t=>{const a=document.createTreeWalker(t,133,null,!1);let o=a.nextNode();for(;s<e.length&&null!==o;){const t=e[s];if(w(t))if(i===t.index){if("node"===t.type){const t=this.processor.handleTextExpression(this.options);t.insertAfterNode(o.previousSibling),this._parts.push(t)}else this._parts.push(...this.processor.handleAttributeExpressions(o,t.name,t.strings,this.options));s++}else i++,"TEMPLATE"===o.nodeName&&n(o.content),o=a.nextNode();else this._parts.push(void 0),s++}};return n(t),u&&(document.adoptNode(t),customElements.upgrade(t)),t}}class x{constructor(t,e,s,i){this.strings=t,this.values=e,this.type=s,this.processor=i}getHTML(){const t=this.strings.length-1;let e="";for(let s=0;s<t;s++){const t=this.strings[s],i=S.exec(t);e+=i?t.substr(0,i.index)+i[1]+i[2]+_+i[3]+g:t+y}return e+this.strings[t]}getTemplateElement(){const t=document.createElement("template");return t.innerHTML=this.getHTML(),t}}const E=t=>null===t||!("object"==typeof t||"function"==typeof t);class O{constructor(t,e,s){this.dirty=!0,this.element=t,this.name=e,this.strings=s,this.parts=[];for(let t=0;t<s.length-1;t++)this.parts[t]=this._createPart()}_createPart(){return new T(this)}_getValue(){const t=this.strings,e=t.length-1;let s="";for(let i=0;i<e;i++){s+=t[i];const e=this.parts[i];if(void 0!==e){const t=e.value;if(null!=t&&(Array.isArray(t)||"string"!=typeof t&&t[Symbol.iterator]))for(const e of t)s+="string"==typeof e?e:String(e);else s+="string"==typeof t?t:String(t)}}return s+t[e]}commit(){this.dirty&&(this.dirty=!1,this.element.setAttribute(this.name,this._getValue()))}}class T{constructor(t){this.value=void 0,this.committer=t}setValue(t){t===p||E(t)&&t===this.value||(this.value=t,d(t)||(this.committer.dirty=!0))}commit(){for(;d(this.value);){const t=this.value;this.value=p,t(this)}this.value!==p&&this.committer.commit()}}class A{constructor(t){this.value=void 0,this._pendingValue=void 0,this.options=t}appendInto(t){this.startNode=t.appendChild(v()),this.endNode=t.appendChild(v())}insertAfterNode(t){this.startNode=t,this.endNode=t.nextSibling}appendIntoPart(t){t._insert(this.startNode=v()),t._insert(this.endNode=v())}insertAfterPart(t){t._insert(this.startNode=v()),this.endNode=t.endNode,t.endNode=this.startNode}setValue(t){this._pendingValue=t}commit(){for(;d(this._pendingValue);){const t=this._pendingValue;this._pendingValue=p,t(this)}const t=this._pendingValue;t!==p&&(E(t)?t!==this.value&&this._commitText(t):t instanceof x?this._commitTemplateResult(t):t instanceof Node?this._commitNode(t):Array.isArray(t)||t[Symbol.iterator]?this._commitIterable(t):t===m?(this.value=m,this.clear()):this._commitText(t))}_insert(t){this.endNode.parentNode.insertBefore(t,this.endNode)}_commitNode(t){this.value!==t&&(this.clear(),this._insert(t),this.value=t)}_commitText(t){const e=this.startNode.nextSibling;t=null==t?"":t,e===this.endNode.previousSibling&&3===e.nodeType?e.data=t:this._commitNode(document.createTextNode("string"==typeof t?t:String(t))),this.value=t}_commitTemplateResult(t){const e=this.options.templateFactory(t);if(this.value instanceof C&&this.value.template===e)this.value.update(t.values);else{const s=new C(e,t.processor,this.options),i=s._clone();s.update(t.values),this._commitNode(i),this.value=s}}_commitIterable(t){Array.isArray(this.value)||(this.value=[],this.clear());const e=this.value;let s,i=0;for(const n of t)void 0===(s=e[i])&&(s=new A(this.options),e.push(s),0===i?s.appendIntoPart(this):s.insertAfterPart(e[i-1])),s.setValue(n),s.commit(),i++;i<e.length&&(e.length=i,this.clear(s&&s.endNode))}clear(t=this.startNode){h(this.startNode.parentNode,t.nextSibling,this.endNode)}}class I extends T{}let U=!1;try{const t={get capture(){return U=!0,!1}};window.addEventListener("test",t,t),window.removeEventListener("test",t,t)}catch(t){}const N=t=>t&&(U?{capture:t.capture,passive:t.passive,once:t.once}:t.capture),k=new class{handleAttributeExpressions(t,e,s,i){const n=e[0];return"."===n?new class extends O{constructor(t,e,s){super(t,e,s),this.single=2===s.length&&""===s[0]&&""===s[1]}_createPart(){return new I(this)}_getValue(){return this.single?this.parts[0].value:super._getValue()}commit(){this.dirty&&(this.dirty=!1,this.element[this.name]=this._getValue())}}(t,e.slice(1),s).parts:"@"===n?[new class{constructor(t,e,s){this.value=void 0,this._pendingValue=void 0,this.element=t,this.eventName=e,this.eventContext=s,this._boundHandleEvent=(t=>this.handleEvent(t))}setValue(t){this._pendingValue=t}commit(){for(;d(this._pendingValue);){const t=this._pendingValue;this._pendingValue=p,t(this)}if(this._pendingValue===p)return;const t=this._pendingValue,e=this.value,s=null==t||null!=e&&(t.capture!==e.capture||t.once!==e.once||t.passive!==e.passive),i=null!=t&&(null==e||s);s&&this.element.removeEventListener(this.eventName,this._boundHandleEvent,this._options),i&&(this._options=N(t),this.element.addEventListener(this.eventName,this._boundHandleEvent,this._options)),this.value=t,this._pendingValue=p}handleEvent(t){"function"==typeof this.value?this.value.call(this.eventContext||this.element,t):this.value.handleEvent(t)}}(t,e.slice(1),i.eventContext)]:"?"===n?[new class{constructor(t,e,s){if(this.value=void 0,this._pendingValue=void 0,2!==s.length||""!==s[0]||""!==s[1])throw new Error("Boolean attributes can only contain a single expression");this.element=t,this.name=e,this.strings=s}setValue(t){this._pendingValue=t}commit(){for(;d(this._pendingValue);){const t=this._pendingValue;this._pendingValue=p,t(this)}if(this._pendingValue===p)return;const t=!!this._pendingValue;this.value!==t&&(t?this.element.setAttribute(this.name,""):this.element.removeAttribute(this.name)),this.value=t,this._pendingValue=p}}(t,e.slice(1),s)]:new O(t,e,s).parts}handleTextExpression(t){return new A(t)}};function P(t){let e=j.get(t.type);void 0===e&&(e={stringsArray:new WeakMap,keyString:new Map},j.set(t.type,e));let s=e.stringsArray.get(t.strings);if(void 0!==s)return s;const i=t.strings.join(g);return void 0===(s=e.keyString.get(i))&&(s=new f(t,t.getTemplateElement()),e.keyString.set(i,s)),e.stringsArray.set(t.strings,s),s}const j=new Map,D=new WeakMap;(window.litHtmlVersions||(window.litHtmlVersions=[])).push("1.0.0");const L=(t,...e)=>new x(t,e,"html",k),M=133;function R(t,e){const{element:{content:s},parts:i}=t,n=document.createTreeWalker(s,M,null,!1);let a=V(i),o=i[a],r=-1,l=0;const c=[];let d=null;for(;n.nextNode();){r++;const t=n.currentNode;for(t.previousSibling===d&&(d=null),e.has(t)&&(c.push(t),null===d&&(d=t)),null!==d&&l++;void 0!==o&&o.index===r;)o.index=null!==d?-1:o.index-l,o=i[a=V(i,a)]}c.forEach(t=>t.parentNode.removeChild(t))}const B=t=>{let e=11===t.nodeType?0:1;const s=document.createTreeWalker(t,M,null,!1);for(;s.nextNode();)e++;return e},V=(t,e=-1)=>{for(let s=e+1;s<t.length;s++){const e=t[s];if(w(e))return s}return-1},H=(t,e)=>`${t}--${e}`;let z=!0;void 0===window.ShadyCSS?z=!1:void 0===window.ShadyCSS.prepareTemplateDom&&(console.warn("Incompatible ShadyCSS version detected.Please update to at least @webcomponents/[email protected] and@webcomponents/[email protected]."),z=!1);const W=["html","svg"],F=new Set;window.JSCompiler_renameProperty=((t,e)=>t);const $={toAttribute(t,e){switch(e){case Boolean:return t?"":null;case Object:case Array:return null==t?t:JSON.stringify(t)}return t},fromAttribute(t,e){switch(e){case Boolean:return null!==t;case Number:return null===t?null:Number(t);case Object:case Array:return JSON.parse(t)}return t}},q=(t,e)=>e!==t&&(e==e||t==t),G={attribute:!0,type:String,converter:$,reflect:!1,hasChanged:q},J=Promise.resolve(!0),K=1,Y=4,Q=8,X=16,Z=32;class tt extends HTMLElement{constructor(){super(),this._updateState=0,this._instanceProperties=void 0,this._updatePromise=J,this._hasConnectedResolver=void 0,this._changedProperties=new Map,this._reflectingProperties=void 0,this.initialize()}static get observedAttributes(){this.finalize();const t=[];return this._classProperties.forEach((e,s)=>{const i=this._attributeNameForProperty(s,e);void 0!==i&&(this._attributeToPropertyMap.set(i,s),t.push(i))}),t}static _ensureClassProperties(){if(!this.hasOwnProperty(JSCompiler_renameProperty("_classProperties",this))){this._classProperties=new Map;const t=Object.getPrototypeOf(this)._classProperties;void 0!==t&&t.forEach((t,e)=>this._classProperties.set(e,t))}}static createProperty(t,e=G){if(this._ensureClassProperties(),this._classProperties.set(t,e),e.noAccessor||this.prototype.hasOwnProperty(t))return;const s="symbol"==typeof t?Symbol():`__${t}`;Object.defineProperty(this.prototype,t,{get(){return this[s]},set(e){const i=this[t];this[s]=e,this._requestUpdate(t,i)},configurable:!0,enumerable:!0})}static finalize(){if(this.hasOwnProperty(JSCompiler_renameProperty("finalized",this))&&this.finalized)return;const t=Object.getPrototypeOf(this);if("function"==typeof t.finalize&&t.finalize(),this.finalized=!0,this._ensureClassProperties(),this._attributeToPropertyMap=new Map,this.hasOwnProperty(JSCompiler_renameProperty("properties",this))){const t=this.properties,e=[...Object.getOwnPropertyNames(t),..."function"==typeof Object.getOwnPropertySymbols?Object.getOwnPropertySymbols(t):[]];for(const s of e)this.createProperty(s,t[s])}}static _attributeNameForProperty(t,e){const s=e.attribute;return!1===s?void 0:"string"==typeof s?s:"string"==typeof t?t.toLowerCase():void 0}static _valueHasChanged(t,e,s=q){return s(t,e)}static _propertyValueFromAttribute(t,e){const s=e.type,i=e.converter||$,n="function"==typeof i?i:i.fromAttribute;return n?n(t,s):t}static _propertyValueToAttribute(t,e){if(void 0===e.reflect)return;const s=e.type,i=e.converter;return(i&&i.toAttribute||$.toAttribute)(t,s)}initialize(){this._saveInstanceProperties(),this._requestUpdate()}_saveInstanceProperties(){this.constructor._classProperties.forEach((t,e)=>{if(this.hasOwnProperty(e)){const t=this[e];delete this[e],this._instanceProperties||(this._instanceProperties=new Map),this._instanceProperties.set(e,t)}})}_applyInstanceProperties(){this._instanceProperties.forEach((t,e)=>this[e]=t),this._instanceProperties=void 0}connectedCallback(){this._updateState=this._updateState|Z,this._hasConnectedResolver&&(this._hasConnectedResolver(),this._hasConnectedResolver=void 0)}disconnectedCallback(){}attributeChangedCallback(t,e,s){e!==s&&this._attributeToProperty(t,s)}_propertyToAttribute(t,e,s=G){const i=this.constructor,n=i._attributeNameForProperty(t,s);if(void 0!==n){const t=i._propertyValueToAttribute(e,s);if(void 0===t)return;this._updateState=this._updateState|Q,null==t?this.removeAttribute(n):this.setAttribute(n,t),this._updateState=this._updateState&~Q}}_attributeToProperty(t,e){if(this._updateState&Q)return;const s=this.constructor,i=s._attributeToPropertyMap.get(t);if(void 0!==i){const t=s._classProperties.get(i)||G;this._updateState=this._updateState|X,this[i]=s._propertyValueFromAttribute(e,t),this._updateState=this._updateState&~X}}_requestUpdate(t,e){let s=!0;if(void 0!==t){const i=this.constructor,n=i._classProperties.get(t)||G;i._valueHasChanged(this[t],e,n.hasChanged)?(this._changedProperties.has(t)||this._changedProperties.set(t,e),!0!==n.reflect||this._updateState&X||(void 0===this._reflectingProperties&&(this._reflectingProperties=new Map),this._reflectingProperties.set(t,n))):s=!1}!this._hasRequestedUpdate&&s&&this._enqueueUpdate()}requestUpdate(t,e){return this._requestUpdate(t,e),this.updateComplete}async _enqueueUpdate(){let t,e;this._updateState=this._updateState|Y;const s=this._updatePromise;this._updatePromise=new Promise((s,i)=>{t=s,e=i});try{await s}catch(t){}this._hasConnected||await new Promise(t=>this._hasConnectedResolver=t);try{const t=this.performUpdate();null!=t&&await t}catch(t){e(t)}t(!this._hasRequestedUpdate)}get _hasConnected(){return this._updateState&Z}get _hasRequestedUpdate(){return this._updateState&Y}get hasUpdated(){return this._updateState&K}performUpdate(){this._instanceProperties&&this._applyInstanceProperties();let t=!1;const e=this._changedProperties;try{(t=this.shouldUpdate(e))&&this.update(e)}catch(e){throw t=!1,e}finally{this._markUpdated()}t&&(this._updateState&K||(this._updateState=this._updateState|K,this.firstUpdated(e)),this.updated(e))}_markUpdated(){this._changedProperties=new Map,this._updateState=this._updateState&~Y}get updateComplete(){return this._updatePromise}shouldUpdate(t){return!0}update(t){void 0!==this._reflectingProperties&&this._reflectingProperties.size>0&&(this._reflectingProperties.forEach((t,e)=>this._propertyToAttribute(e,this[e],t)),this._reflectingProperties=void 0)}updated(t){}firstUpdated(t){}}tt.finalized=!0;const et="adoptedStyleSheets"in Document.prototype&&"replace"in CSSStyleSheet.prototype;Symbol(),(window.litElementVersions||(window.litElementVersions=[])).push("2.0.1");const st=t=>t.flat?t.flat(1/0):function t(e,s=[]){for(let i=0,n=e.length;i<n;i++){const n=e[i];Array.isArray(n)?t(n,s):s.push(n)}return s}(t);class it extends tt{static finalize(){super.finalize(),this._styles=this.hasOwnProperty(JSCompiler_renameProperty("styles",this))?this._getUniqueStyles():this._styles||[]}static _getUniqueStyles(){const t=this.styles,e=[];return Array.isArray(t)?st(t).reduceRight((t,e)=>(t.add(e),t),new Set).forEach(t=>e.unshift(t)):t&&e.push(t),e}initialize(){super.initialize(),this.renderRoot=this.createRenderRoot(),window.ShadowRoot&&this.renderRoot instanceof window.ShadowRoot&&this.adoptStyles()}createRenderRoot(){return this.attachShadow({mode:"open"})}adoptStyles(){const t=this.constructor._styles;0!==t.length&&(void 0===window.ShadyCSS||window.ShadyCSS.nativeShadow?et?this.renderRoot.adoptedStyleSheets=t.map(t=>t.styleSheet):this._needsShimAdoptedStyleSheets=!0:window.ShadyCSS.ScopingShim.prepareAdoptedCssText(t.map(t=>t.cssText),this.localName))}connectedCallback(){super.connectedCallback(),this.hasUpdated&&void 0!==window.ShadyCSS&&window.ShadyCSS.styleElement(this)}update(t){super.update(t);const e=this.render();e instanceof x&&this.constructor.render(e,this.renderRoot,{scopeName:this.localName,eventContext:this}),this._needsShimAdoptedStyleSheets&&(this._needsShimAdoptedStyleSheets=!1,this.constructor._styles.forEach(t=>{const e=document.createElement("style");e.textContent=t.cssText,this.renderRoot.appendChild(e)}))}render(){}}it.finalized=!0,it.render=((t,e,s)=>{const i=s.scopeName,n=D.has(e),a=e instanceof ShadowRoot&&z&&t instanceof x,o=a&&!F.has(i),r=o?document.createDocumentFragment():e;if(((t,e,s)=>{let i=D.get(e);void 0===i&&(h(e,e.firstChild),D.set(e,i=new A(Object.assign({templateFactory:P},s))),i.appendInto(e)),i.setValue(t),i.commit()})(t,r,Object.assign({templateFactory:(t=>e=>{const s=H(e.type,t);let i=j.get(s);void 0===i&&(i={stringsArray:new WeakMap,keyString:new Map},j.set(s,i));let n=i.stringsArray.get(e.strings);if(void 0!==n)return n;const a=e.strings.join(g);if(void 0===(n=i.keyString.get(a))){const s=e.getTemplateElement();z&&window.ShadyCSS.prepareTemplateDom(s,t),n=new f(e,s),i.keyString.set(a,n)}return i.stringsArray.set(e.strings,n),n})(i)},s)),o){const t=D.get(r);D.delete(r),t.value instanceof C&&((t,e,s)=>{F.add(s);const i=t.querySelectorAll("style");if(0===i.length)return void window.ShadyCSS.prepareTemplateStyles(e.element,s);const n=document.createElement("style");for(let t=0;t<i.length;t++){const e=i[t];e.parentNode.removeChild(e),n.textContent+=e.textContent}if(s=s,W.forEach(t=>{const e=j.get(H(t,s));void 0!==e&&e.keyString.forEach(t=>{const{element:{content:e}}=t,s=new Set;Array.from(e.querySelectorAll("style")).forEach(t=>{s.add(t)}),R(t,s)})}),function(t,e,s=null){const{element:{content:i},parts:n}=t;if(null===s||void 0===s)return void i.appendChild(e);const a=document.createTreeWalker(i,M,null,!1);let o=V(n),r=0,l=-1;for(;a.nextNode();)for(l++,a.currentNode===s&&(r=B(e),s.parentNode.insertBefore(e,s));-1!==o&&n[o].index===l;){if(r>0){for(;-1!==o;)n[o].index+=r,o=V(n,o);return}o=V(n,o)}}(e,n,e.element.content.firstChild),window.ShadyCSS.prepareTemplateStyles(e.element,s),window.ShadyCSS.nativeShadow){const s=e.element.content.querySelector("style");t.insertBefore(s.cloneNode(!0),t.firstChild)}else{e.element.content.insertBefore(n,e.element.content.first:
:  **** HAD TO CUT PART OF IT BECAUSE BODY IS LIMITED TO 32767 CHARACTERS ****
      <div id='container' class='horizontal layout justified'>
        <state-info
            hass='[[hass]]'
            class='state-info'
            state-obj='[[stateObj]]'
            in-dialog='[[showLastChanged(stateObj, inDialog, extra)]]'
            secondary-line$='[[hasExtra(extra)]]'>
          <template is='dom-repeat' items='[[extra]]'>
            <div>[[item]]</div>
          </template>
        </state-info>
        <dynamic-with-extra
            hass='[[hass]]'
            control-element='[[controlElement]]'
            in-dialog='[[inDialog]]'>
        </dynamic-with-extra>
      </div>
      `}})}function gt(){const t=["configurator"],e={light:1,cover:4,climate:1},s={toggle:"ha-entity-toggle",display:"",cover:"ha-cover-controls"};customElements.define("state-card-custom-ui",class extends Polymer.Element{static get properties(){return{hass:Object,inDialog:{type:Boolean,value:!1},stateObj:Object}}static get observers(){return["inputChanged(hass, inDialog, stateObj)"]}connectedCallback(){super.connectedCallback();const t=this.parentNode.parentNode;"DIV"===t.tagName&&(t.classList.contains("state")||t.classList.contains("child-card"))&&(this._container=t,t.style.setProperty("background-color","var(--paper-card-background-color, inherit)"),t.updateStyles||(t.updateStyles=(e=>{Object.keys(e).forEach(s=>{t.style.setProperty(s,e[s])})}))),this._isAttached=!0,this.inputChanged(this.hass,this.inDialog,this.stateObj)}disconnectedCallback(){this._isAttached=!1,this._container&&(this._container.updateStyles({display:"",margin:"",padding:""}),i(this._container,this.hass.themes||{default_theme:"default",themes:{}},"default"),this._container=null),super.disconnectedCallback()}badgeMode(t,e,s){const i=[];if("group"===s)e.attributes.entity_id.forEach(s=>{const n=t.states[s];n?e.attributes.badges_list&&!e.attributes.badges_list.includes(n.entity_id)||i.push(window.customUI.maybeChangeObject(this,n,!1,!1)):console.warn(`Unknown ID ${s} in group ${e.entity_id}`)});else if(i.push(e),this._container){this._container.style.display="inline-block";const t={display:"inline-block"};this._container.classList.contains("state")&&(t.margin="var(--ha-badges-card-margin, 0)"),this.updateStyles(t)}o(this,"HA-BADGES-CARD",{hass:t,states:i}),this._container&&this._container.updateStyles({width:"var(--ha-badges-card-width, initial)","text-align":"var(--ha-badges-card-text-align, initial)"}),this.lastChild.style.fontSize="85%",this.style.setProperty("--ha-state-label-badge-margin-bottom","0")}cleanBadgeStyle(){this._container&&this._container.updateStyles({display:"",width:"","text-align":""}),this.updateStyles({display:"",margin:""})}applyThemes(t,e){let s=this,n="default";this._container&&(s=this._container),e.attributes.theme&&(n=e.attributes.theme),i(s,t.themes||{default_theme:"default",themes:{}},n)}maybeHideEntity(t){return t?(this._container&&this._container.updateStyles({margin:"",padding:""}),!1):(this.lastChild&&this.removeChild(this.lastChild),this._container&&this._container.updateStyles({margin:"0",padding:"0"}),!0)}sliderEligible_(t,s,i){return!i&&e[t]&&e[t]&s.attributes.supported_features&&s.attributes.state_card_mode&&"no-slider"!==s.attributes.state_card_mode}inputChanged(t,e,s){if(!s||!t||!this._isAttached)return;const i=a(s),n=window.customUI.maybeChangeObject(this,s,e,!0);this.maybeHideEntity(n)||(this.applyThemes(t,n),e||"badges"!==n.attributes.state_card_mode?this.regularMode_(t,e,n,i):this.badgeMode(t,n,i))}regularMode_(e,i,n,c){this.cleanBadgeStyle();const d={hass:e,stateObj:n,inDialog:i},u=function(t,e){if("unavailable"===e.state)return"display";const s=a(e);return l.includes(s)?s:function(t,e){const s=a(e);return"group"===s?"on"===e.state||"off"===e.state:"climate"===s?r(e,4096):function(t,e){const s=t.services[e];return!!s&&("lock"===e?"lock"in s:"cover"===e?"open_cover"in s:"turn_on"in s)}(t,s)}(t,e)&&"hidden"!==e.attributes.control?"toggle":"display"}(e,n);let h;const p=n.attributes.state_card_custom_ui_secondary;"light"===c&&this.sliderEligible_(c,n,i)?(Object.assign(d,{controlElement:"ha-entity-toggle",serviceMin:"turn_off",serviceMax:"turn_on",valueName:"brightness",domain:c}),h="state-card-with-slider"):"cover"===c&&this.sliderEligible_(c,n,i)?(Object.assign(d,{controlElement:"ha-cover-controls",max:100,serviceMin:"close_cover",serviceMax:"set_cover_position",setValueName:"position",valueName:"current_position",nameOn:"open",domain:c}),h="state-card-with-slider"):"climate"===c&&this.sliderEligible_(c,n,i)?(Object.assign(d,{controlElement:"ha-climate-state",min:n.attributes.min_temp||-100,max:n.attributes.max_temp||200,serviceMin:"set_temperature",serviceMax:"set_temperature",valueName:"temperature",nameOn:"",domain:c}),h="state-card-with-slider"):void 0!==s[u]?(d.controlElement=s[u],h="state-card-without-slider"):n.attributes.show_last_changed&&!t.includes(u)&&(d.inDialog=!0),"unavailable"===n.state&&(d.controlElement=""),void 0!==n.attributes.control_element&&(d.controlElement=n.attributes.control_element),o(this,(p||h||`STATE-CARD-${u}`).toUpperCase(),d)}})}Polymer&&Polymer.Element&&customElements.get("home-assistant")?ut():customElements.whenDefined("home-assistant").then(()=>ut()),customElements.whenDefined("state-card-display").then(()=>{customElements.define("dynamic-with-extra",class extends(customElements.get("state-card-display")){static get template(){return ct`
      <style is="custom-style" include="iron-flex iron-flex-alignment iron-flex-factors"></style>
      <style>
        :host {
          display: inline-block;
        .control-wrapper {
          margin: -4px -16px -4px 0;
          padding: 4px 16px;
        ha-state-label-badge {
          margin-left: 8px;
        dynamic-element {
          display: block;
          text-align: right;
        #overlay {
          position: absolute;
          left: 0;
          right: 0;
          top: 0;
          bottom: 0;
          text-align: right;
          z-index: 1;
        #lock {
          margin-top: 8px;
          opacity: 0.3;
          margin-right: 7px;
        #lock.ha-cover-controls {
          margin-right: 52px;
          background-color: white;
        .extra {
          margin-bottom: -16px;
          --ha-label-badge-size: 36px;
          --ha-label-badge-font-size: 1.2em;
        .state {
          @apply --paper-font-body1;
          color: var(--primary-text-color);
          margin-left: 16px;
          text-align: right;
          line-height: 40px;
      </style>
      <div class$='[[extraClass(extraObjVisible)]] horizontal layout'>
        <template is='dom-if' if='[[extraObjVisible]]'>
                    items='[[extraObj]]'
                    on-dom-change='extraDomChanged'>
            <ha-state-label-badge hass='[[hass]]' state='[[item]]'></ha-state-label-badge>
          </template>
        </template>
        <template is='dom-if' if='[[_showControl(inDialog, stateObj)]]'>
          <template is='dom-if' if='[[controlElement]]'>
            <div class="control-wrapper">
              <dynamic-element
                  class='flex'
                  state-obj="[[stateObj]]"
                  hass='[[hass]]'
                  element-name='[[controlElement]]'>
              </dynamic-element>
              <template is='dom-if' if='[[isConfirmControls(stateObj)]]'>
                <div id="overlay" on-click='clickHandler'>
                  <template is='dom-if' if='[[stateObj.attributes.confirm_controls_show_lock]]'>
                    <iron-icon id="lock" class$="[[controlElement]]" icon="mdi:lock-outline"></iron-icon>
                  </template>
                </div>
              </template>
            </div>
          </template>
          <template is='dom-if' if='[[!controlElement]]'>
            <div class='state'>[[computeStateDisplay(stateObj)]]</div>
          </template>
        </template>
      </div>
      `}static get properties(){return{hass:Object,inDialog:{type:Boolean,value:!1},stateObj:Object,controlElement:String,extraObj:{type:Array,computed:"computeExtra(hass, stateObj, _attached)"},_attached:Boolean,extraObjVisible:{type:Boolean,computed:"computeExtraVisible(extraObj, inDialog)"}}}connectedCallback(){super.connectedCallback(),this._attached=!0}disconnectedCallback(){this._isAttached=!1,super.disconnectedCallback()}computeExtra(t,e,s){if(!e.attributes.extra_badge||!s)return[];let i=e.attributes.extra_badge;return Array.isArray(i)||(i=[i]),i.map(s=>{let i=null;if(s.entity_id&&t.states[s.entity_id]?i=Object.assign({},window.customUI.maybeChangeObject(this,t.states[s.entity_id],this.inDialog,!1)):s.attribute&&void 0!==e.attributes[s.attribute]&&(i={state:String(e.attributes[s.attribute]),entity_id:"none.none",attributes:{unit_of_measurement:s.unit}}),!i)return null;let n=s.blacklist_states;return void 0!==n&&(Array.isArray(n)||(n=[n]),n.some(t=>RegExp(t).test(i.state.toString())))?null:(i._entityDisplay="",i.attributes=Object.assign({},{friendly_name:""}),i)}).filter(t=>null!=t)}computeExtraVisible(t,e){return!(e||!t)&&0!==t.length}extraClass(t){return t?"extra":""}_showControl(t,e){return!!t||!e.attributes.hide_control}computeStateDisplay(t){return super.computeStateDisplay(this.haLocalize||this.localize,t)}isConfirmControls(t){return t.attributes.confirm_controls||t.attributes.confirm_controls_show_lock}clickHandler(t){this.root.querySelector("#overlay").style.pointerEvents="none";const e=this.root.querySelector("#lock");e&&(e.icon="mdi:lock-open-outline",e.style.opacity="0.1"),window.setTimeout(()=>{this.root.querySelector("#overlay").style.pointerEvents="",e&&(e.icon="mdi:lock-outline",e.style.opacity="")},5e3),t.stopPropagation()}applyThemes(t,e,s){const n=s.attributes.theme||"default";i(e,t.themes||{default_theme:"default",themes:{}},n)}extraDomChanged(){this.root.querySelectorAll("ha-state-label-badge").forEach(t=>{this.applyThemes(this.hass,t,t.state)})}})}),Polymer&&Polymer.Element&&customElements.get("home-assistant")?ht():customElements.whenDefined("home-assistant").then(()=>ht()),Polymer&&Polymer.Element&&customElements.get("home-assistant")?pt():customElements.whenDefined("home-assistant").then(()=>pt()),Polymer&&Polymer.Element&&customElements.get("home-assistant")?mt():customElements.whenDefined("home-assistant").then(()=>mt()),Polymer&&Polymer.Element&&customElements.get("home-assistant")?gt():customElements.whenDefined("home-assistant").then(()=>gt())},function(t,e){window.JSCompiler_renameProperty=function(t){return t}}]);
//# sourceMappingURL=scripts.js.map
//# sourceURL=https://***.***.***.***:8123/local/custom_ui/state-card-custom-ui.html.js
:0:0 Script error.
I don’t recall when it started to happen but it wasn’t with 105.
I’m seeing this in the code itself:
mdi:lock-outline
And it’s the only ‘mdi:’ text there so it seems to point to my alarm panel. It gives this error whenever I go into Integrations/Devices/Entities/Areas although my alarm panel entities/devices do not show there. I only see it in the deprecated Developer Tools State_UI and in Lovelace. It’s added through envisalink in configuration as such:
envisalink:
  host: !secret envisalinkhost
  panel_type: DSC
  user_name: !secret envisalinkuser
  password: !secret envisalinkpw
  code: ''
  port: 4025
  evl_version: 4
  keepalive_interval: 60
  zonedump_interval: 30
  timeout: 10
  panic_type: Police
  zones:
    1:
      type: 'door'
    2:
      type: 'door'
    3:
      type: 'motion'
    4:
      type: 'motion'
    5:
      type: 'smoke'
    6:
      type: 'moisture'
    9:
      type: 'garage_door'
  partitions:
    1:
      name: 'Alarme de la maison'
Have I done something wrong there?
usually front end errors are related to out of date cache. CTRL+F5 usually fixes them.
Thanks but unfortunately, it still does it. Tried with both Chrome and Firefox (my preferred browser) after both a Ctrl-F5 and fully clearing cache and cookies.
Although Chrome only logs this in the error log
2020-02-10 21:41:26 ERROR (MainThread) [frontend.js.latest.202001302] https://***.***.***.***:8123/local/custom_ui/state-card-custom-ui.html.js:27:8908 Uncaught TypeError: e.push is not a function
That appears to be coming from custom-ui, do you still use that?
Not sure. I use Lovelace I believe. How do I find out which one I’m using?
Well, custom_ui suppliments lovelace or the states page (old ui). You must be using it. And you would have had to install it. It was the only way to get icons to change color way back in the day.
My installation is less than two months old. Looking at the URL in ‘Overview’, it does have …:8123/lovelace so it makes be believe that I do in fact use lovelace?
ya but look at the error:
https://...:8123/local/custom_ui/state-card-custom-ui.html
That’s directly referencing custom_ui and the state-card that custom-ui used.
But it’s only hit when I go into Integrations/Devices/Entities/Areas from within Configuration. I don’t get the error when I’m in the ‘Overview’. Maybe the configuration code uses custom_ui somehow?
I doubt it. It’s referencing a location on your local system.
config/www/custom_ui/state-card-custom-ui.html
I looked and can’t find where this is specified. I looked at the raw Lovelace code and it’s nowhere to be found :frowning:
you looked in your config folder, inside the www folder, inside the custom_ui folder?
:blush: Yep, it was there. However even after deleting that /www/custom_ui directory (don’t recall what I was trying to do with it) and reloading the server, I still get the error!
Had in configuration.yaml
#  extra_html_url:                                                               # For custo ui
#    - /local/custom_ui/state-card-custom-ui.html
#  extra_html_url_es5:
#    - /local/custom_ui/state-card-custom-ui-es5.html
Which I commented out as you can see and rebooted again HA. Still get the error.
grep custom_ui * yields no result beside configuration.yaml, update.sh (which was put there when I downloaded that code), home-assistant.log and home-assistant_v2.db. So don’t know where it’s still being loaded from…
Edit: Well, custom_ui is used by my thermostats so they show the power being used. I guess I’ll have to live with the error in my logs…
