ERROR (MainThread) [homeassistant.components.sensor] systemmonitor: Error on device update!
Recently checked my log for possible hick ups and errors, and saw this output, which I don’t understand. It’s something minor for sure, and it seems to have something to do with disk_usage sensor.
This is hassio 0.105.5 running.
Thank you!
2020-03-03 11:03:09 ERROR (MainThread) [homeassistant.components.sensor] systemmonitor: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 304, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 461, in async_device_update
    await self.hass.async_add_executor_job(self.update)
  File "/usr/src/homeassistant/homeassistant/components/systemmonitor/sensor.py", line 142, in update
    self._state = round(psutil.disk_usage(self.argument).free / 1024 ** 3, 1)
  File "/usr/local/lib/python3.7/site-packages/psutil/__init__.py", line 2120, in disk_usage
    return _psplatform.disk_usage(path)
  File "/usr/local/lib/python3.7/site-packages/psutil/_psposix.py", line 125, in disk_usage
    st = os.statvfs(path)
FileNotFoundError: [Errno 2] No such file or directory: ''
Have you found a solution for this issue? Have the same problem on 0.107.7 freshly installed on a NUC.
Nope. Unfortunately not
