Error message about emulated_hue integration in HA log
Hello
Could someone help me to understand the following message in HA log:
  • Unkown entity number : 2 not found in emulated_hue_ids.json
    components/emulated_hue/hue_api.py (error)
Below, the contents of the emulated_hue_ids.json
{ "1": "input_boolean.tv" }
This file is automatically created when emulated_hue integration is actived
and a partial contents of configuration.yaml about emulated_hue integration :
emulated_hue:
host_ip: 192.168.1.18
listen_port: 80
#advertise_ip: 192.168.1.18
#advertise_port: 80
#off_maps_to_on_domains:
#- script
#- scene
expose_by_default: true
exposed_domains:
#- light
- input_boolean
entities:
input_boolean.TV_Test:
hidden: false
I have the same message for ten numbers.
Thank you in advance for your help
