Keos
(Claudiu Ivanescu)
November 13, 2017, 9:55am
1
I’m trying to start a home assistant and doing step by step I’m stuck in something strange.
For example I want that if sensor.random above 10 to give a message, else dismiss it.
My code from automations.yaml is:
alias: NumberOn
platform: numeric_state
entity_id: sensor.aleator
above: 10
service: persistent_notification.create
message: "Random number peste 10"
title: "Numarul este {{ sensor.aleator.state }}"
notification_id: "201711131"
alias: NumberOff
below: 10
# When next line activated - gives error
service: persistent_notification.dismiss
date:
The error is:
2017-11-13 09:41:20 ERROR (Thread-2) [homeassistant.util.yaml] YAML file /opt/homeassistant/automations.yaml contains duplicate key “alias”. Check lines 0 and 12.
2017-11-13 09:41:20 ERROR (Thread-2) [homeassistant.util.yaml] YAML file /opt/homeassistant/automations.yaml contains duplicate key “trigger”. Check lines 1 and 13.
2017-11-13 09:41:20 ERROR (Thread-2) [homeassistant.util.yaml] YAML file /opt/homeassistant/automations.yaml contains duplicate key “action”. Check lines 5 and 17.
P.S. I’ve read multiple webpages and docs, but I from their example it should work. I run the last version of hass but with yarl 0.13
vladosam
(Vladimir)
November 13, 2017, 10:49am
2
You have date instead of data in second automation.
Keos:
date:
Keos
(Claudiu Ivanescu)
November 13, 2017, 12:19pm
3
Ups… sorry, indeed now accepted.
But now the only automation script that runs is the last is NumberJos
I don’t understand why. Here is the new code:
alias: NumberSus
entity_id: sensor.random_sensor
above: 10
message: "Random number is: {{ states('sensor.random_sensor') }}"
title: "Number above 10"
# notification_id: "201711131"
alias: NumberJos
below: 10
title: "Number below 10"
with multiple automations in a file you must use a “-
” to denote separate automations. Put a “-
” in front of each alias:
. If it still complains, you may then also need to indent everything with 2 spaces.
Example:
- alias: NumberJos
below: 10
Keos
(Claudiu Ivanescu)
November 13, 2017, 1:29pm
5
Now I get it… even if you are using an file you should have an -id: before
I added “-id: numbersus and -id: numberjos” before each alias and now is working corectly.
Keos
(Claudiu Ivanescu)
November 13, 2017, 1:30pm
6
I’ll ttry with “- alias” but now with “- id” is working.
Thanks,
That works too. alias:
gives your automations a friendly name, id:
gives them an identity so they show up in the frontend editor.
Regardless which one you put the -
in front of, it will fix your error.
Keos
(Claudiu Ivanescu)
November 13, 2017, 1:39pm
8
Yes, indeed it works perfectly now. Thanks.
