Hi everyone, I’ve deployed Home Assistant in dev mode on my local machine using dev-containers, and I’m getting this error while I run the “hass” command, any idea on what could be the reason?
root ➜ /workspaces/core (dev) $ hass
2021-04-30 11:56:16 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //root/.homeassistant/home-assistant_v2.db was shutdown cleanly
2021-04-30 11:56:17 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/workspaces/core/homeassistant/components/zeroconf/__init__.py", line 182, in _async_zeroconf_hass_start
await hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/workspaces/core/homeassistant/components/zeroconf/__init__.py", line 236, in _register_hass_zc_service
info = ServiceInfo(
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 1807, in __init__
if not type_.endswith(service_type_name(name, strict=False)):
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 301, in service_type_name
raise BadTypeInNameException("Type '%s' must not start with '.'" % type_)
zeroconf.BadTypeInNameException: Type '._home-assistant._tcp.local.' must not start with '.'
I post also the configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
logger:
default: info
logs:
homeassistant.components.cloud: debug
frontend:
development_repo: /workspaces/frontend/
