Error on Hampton Bay fan light
I’ve got two Hampton Bay Zigbee fans/controllers. They’ve been working with no issues.
With the last HA update, I’ve started getting the following error pop up when I turn on or off either light. The lights still work, and the fans do not cause an error.
When I click to turn on a light:
Failed to call service light/turn_on. ‘EmberStatus’ object is not subscriptable
When I click to turn off a light:
Failed to callservice light/turn_off. ‘EmberStatus’ object is not subscriptable
Does anyone know how I can stop this error from happening?
If using ZHA then report it; the quirk probably needs to be updated because changes to zha-quirks/zigpy
https://github.com/home-assistant/core/issues
https://github.com/zigpy/zha-device-handlers/issues
https://www.home-assistant.io/integrations/zha#reporting-issues
https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
PS: There were larger changes to zha-quirks/zigpy libraries for 2022.4 which might have broken some quirks if they did not follow the Zigbee Cluster Library Specification, so probably quirk need to be fixed.
I am seeing the same issue with this light. Have you reported it yet?
I have not - not at my PC. LOL Feel free, I won’t be able to for a while.
