I am new to this forum.
I have a problem with the samba share module version 10.0.0
I have a problem with the samba share module version 10.0.0: once configured when I launch a samba share, I see the raspihaos share but I get an error "impossible to load the list of shares, invalid argument.
thank you to help me
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/samba.sh
[23:54:57] INFO: Hostname: raspiHAOS.local
[23:54:57] INFO: Interfaces: eth0 wlan0
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user homeassistant.
cont-init: info: /etc/cont-init.d/samba.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nmbd (no readiness notification)
services-up: info: copying legacy longrun smbd (no readiness notification)
s6-rc: info: service legacy-services successfully started
added interface eth0 ip=2a01:cb04:9ad:cf00:c5ff:26df:287c:9819 bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=192.168.10.11 bcast=192.168.10.255 netmask=255.255.255.0
interpret_interface: Can't find address for wlan0
smbd version 4.15.7 started.
Copyright Andrew Tridgell and the Samba Team 1992-2021
uid=0 gid=0 euid=0 egid=0
nmbd version 4.15.7 started.
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
Processing section "[media]"
INFO: Profiling support unavailable in this build.
making subnet name:192.168.10.11 Broadcast address:192.168.10.255 Subnet mask:255.255.255.0
create_subnets: ignoring non IPv4 interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
waiting for connections
netbios connect: name1=RASPIHAOS.LOCAL0x20 name2= 0x0
netbios connect: local=raspihaos.local remote=, name type = 0
