Error rendering data - not dictionary, but it's ok?
Hello all,
I’m trying to create automation, that will take datetime helpers, calculate days difference between them, take number helper and divide it with previously calculated diff.
I got error " Error rendering data template: Result is not a Dictionary" when trying to set number helper with result of calculations.
My code, as follows:
action: input_number.set_value
metadata: {}
data: “{{ state(‘input_number.zaladunek_pieca_kg’) | int / (state('input_datetime.zaladunek_pieca_ostatni) | as_datetime - state(‘input_datetime.zaladunek_pieca’) | as_datetime).days}}”
entity_id: input_number.spalanie_na_dobe_kg
Is it correct or I need to change something?
This automation will be triggered on input.zaladunek_pieca state changed and will calculate avg. fuel consumption for central heating system.
Thanks in advance!
Plz fix your post to show the correct code: How to help us help you - or How to ask a good question
Since indentation and such is very important it helps with helping.
