ERROR returned from Supervisor: System is not ready with state: setup HELP!
Hi so my HA has killed itself i think. I’ve got it running on a Lenovo Mini PC on an SSD. And last night i accidentally pulled the power plug for the PC. After realising it i plugged it back in but since then HA is not starting up. I cant get access to the GUI and on the CLI screen (connected to the PC’s displayport output) it gives an error saying “Error returned from supervisor: System is not ready with state: setup”
I’ve obviously done some googling and people have suggested trying typing “banner” to restart the CLI in some way and that has worked for most but for me it doesn’t do anything. It shows the Home Assistant logo again and then after a couples minutes gives the same error.
Any help is appreciated!
This is no suicide, it’s manslaughter! :grin:
(sorry, not helpful, but I couldn’t resist)
Same problem on my Raspberry Pi 4B 8 GB with HAOS. “banner” does not help, nor does rebooting
Home Assistant observer
Supervisor: 	Connected
Supported: 	Processing...
Healthy: 	Processing...
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:46:58] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[17:46:58] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
24-01-05 17:47:04 INFO (MainThread) [__main__] Initializing Supervisor setup
24-01-05 17:47:04 INFO (MainThread) [supervisor.utils.sentry] Initializing Supervisor Sentry
24-01-05 18:47:04 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
24-01-05 18:47:04 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
24-01-05 18:47:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-01-05 18:47:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-05 18:47:04 INFO (MainThread) [__main__] Setting up Supervisor
24-01-05 18:47:04 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-01-05 18:47:04 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-01-05 18:47:06 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-05 18:47:06 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-05 18:47:06 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-05 18:47:07 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-05 18:47:08 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-01-05 18:47:08 ERROR (MainThread) [supervisor.host.apparmor] Can't load profile hassio-supervisor: Can't load profile '/mnt/data/supervisor/apparmor/hassio-supervisor': exit status 1
24-01-05 18:47:08 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-01-05 18:47:08 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-01-05 18:47:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-01-05 18:47:08 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-01-05 18:47:08 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-01-05 18:47:18 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-01-05 18:47:18 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-01-05 18:47:18 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-01-05 18:47:18 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-01-05 18:47:28 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-01-05 18:47:28 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-01-05 18:47:28 INFO (MainThread) [supervisor.plugins.base] No audio plugin Docker image ghcr.io/home-assistant/aarch64-hassio-audio found.
24-01-05 18:47:28 INFO (MainThread) [supervisor.plugins.audio] Setup Audio plugin
24-01-05 18:47:28 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2023.12.0.
24-01-05 18:47:29 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0/json: Internal Server Error ("layer does not exist")
24-01-05 18:47:29 WARNING (MainThread) [supervisor.plugins.audio] Error on installing Audio plugin, retrying in 30sec
24-01-05 18:47:59 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2023.12.0.
24-01-05 18:48:01 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0/json: Internal Server Error ("layer does not exist")
and so on and so on
