Error starting zigbee2mqtt with WSonoff Zigbee 3.0 Dongle type P
Hi out there
I had originally installed ZHA on my Sonoff, but since I wanted to have 20dB og gain, I seem to need mosquitto installed:
I have removed ZHA from my system and reboot
I have flashed dongle to 20220219 firmware
I have pressed the reset buttom on the dongle for 10s, to make sure it is “clean”
I have installed MQTT Mosquitto broker and it runs
I have installed mosquitto2mqtt with the parameters mqtt server and serial
mqtt:
server: mqtt://localhost:1883
serial:
port: /dev/ttyUSB0
When pressing start it comes with error, unable to start :slight_smile:
Zigbee2MQTT:info 2022-08-26 14:31:15: Starting Zigbee2MQTT version 1.27.0 (commit #unknown)
Zigbee2MQTT:info 2022-08-26 14:31:15: Starting zigbee-herdsman (0.14.46)
Zigbee2MQTT:error 2022-08-26 14:31:16: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-08-26 14:31:16: Failed to start zigbee
I have tried all the ideas on:
https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html
Even tried to remove both add-ons restart, insert dongle after resert. reinstalled MQTT and Z2M, but error persists
Anyone who has the golden idea?
Marinus
Is ZHA disabled? Even if removed, HA will auto detect the stick and add ZHA back.
@Jerrm
I tried to use ZHA_remove, that a dutch guy posted, that worked. thanks
Marinus
