Thanks for your reply. ive added the code to the configuration.yaml and now i am getting this
Zigbee2MQTT:info 2022-09-27 12:47:55: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-27.12-47-55' filename: log.txt
Zigbee2MQTT:info 2022-09-27 12:47:55: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-27 12:47:55: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:error 2022-09-27 12:47:55: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-27 12:47:55: Failed to start zigbee
Zigbee2MQTT:error 2022-09-27 12:47:55: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-27 12:47:55: Exiting...
Zigbee2MQTT:error 2022-09-27 12:47:55: Error: No path provided and failed to auto detect path
at Function.create (/app/node_modules/zigbee-herdsman/src/adapter/adapter.ts:81:23)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:24)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:109:5)
[12:47:55] INFO: Handing over control to Zigbee2MQTT Core ...
