Error Template
Hi to all, on every startup i recive the following error:
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:71
Integration: template (documentation, issues)
First occurred: 12:55:50 (2 occurrences)
Last logged: 12:55:50
 TemplateError('ZeroDivisionError: float division by zero') while processing template 'Template("{{ (states("sensor.shelly_em_assorbimento_ch1")|float / states("sensor.shelly_em_tensione")|float)|float|round(1) }}")' for attribute '_state' in entity 'sensor.shelly_em_corrente_ch1'
TemplateError('ZeroDivisionError: float division by zero') while processing template 'Template("{{ (states("sensor.shelly_em_assorbimento_ch2")|float / states("sensor.shelly_em_tensione")|float)|float|round(1) }}")' for attribute '_state' in entity 'sensor.shelly_em_corrente_ch2'
second
Logger: homeassistant.helpers.event
Source: helpers/template.py:370
Error while processing template: Template("{{ (states("sensor.shelly_em_assorbimento_ch1")|float / states("sensor.shelly_em_tensione")|float)|float|round(1) }}")
Error while processing template: Template("{{ (states("sensor.shelly_em_assorbimento_ch2")|float / states("sensor.shelly_em_tensione")|float)|float|round(1) }}")
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 368, in async_render
    render_result = compiled.render(kwargs)
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
    reraise(*rewrite_traceback_stack(source=source))
  File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 1, in top-level template code
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 477, in async_render_to_info
render_info._result = self.async_render(variables, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 370, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ZeroDivisionError: float division by zero
this error cause a malfunction of the system that monitors electricity.
So obviously sensor.shelly_em_tensione does not return a numeric state at the time of evaluation.
this the sensor
- platform: mqtt
    name: "Shelly EM Tensione"
    state_topic: "shellies/shellyem-CONSUMI/emeter/0/voltage"
    unit_of_measurement: "Volt"
You must guard the case of sensor.shelly_em_tensione not returning a numeric value of being unavailable, since "{{ states(‘sensor.my_missing_sensor’) | float }} will return 0, giving you a division by zero.
Btw:
  • It‘s probably just a copy 'n paste error, but indentation is wrong. It should be all on the same level.
  • Unit of measurement should be ‘V’, not Volt.
First of all, thank you very much.
now i’m not very smart about this, would you tell me where i got the code wrong?
    sensors:
      shelly_em_corrente_ch1:
        friendly_name: "Shelly EM Corrente ch1"
        value_template: '{{ (states("sensor.shelly_em_assorbimento_ch1")|float / states("sensor.shelly_em_tensione")|float)|float|round(1) }}'
        unit_of_measurement: "Ampere"
        icon_template: mdi:current-ac
      shelly_em_corrente_ch2:
        friendly_name: "Shelly EM Corrente ch2"
        value_template: '{{ (states("sensor.shelly_em_assorbimento_ch2")|float / states("sensor.shelly_em_tensione")|float)|float|round(1) }}'
    sensors:
        value_template: >
          {% set ch1 = states("sensor.shelly_em_assorbimento_ch1")|float %}
          {% set tensione = states("sensor.shelly_em_tensione")|float %}
          {% if tensione != 0 %} {{ (ch1 / tensione) | round(1) }}
          {% else %} {{ states("sensor.shelly_em_corrente_ch1") }}
          {% endif %}
        value_template: >
          {% set ch2 = states("sensor.shelly_em_assorbimento_ch2")|float %}
          {% if tensione != 0 %} {{ (ch2 / tensione) | round(1) }}
          {% else %} {{ states("sensor.shelly_em_corrente_ch2") }}
          {% endif %}
  • If tensione is not zero, it reports the result of (ch1 / tensione) | round(1)
  • If tensione is zero, it reports its existing value
Implemented now let’s see if it goes, thanks a lot.
I take this opportunity for a problem always inherent to electricity, I have implemented a package for the control of consumption, but at each update / restart of HA the values ​​are wrong, instead of marking 4.2 kwh it marks 3456 kwh. if I don’t restart it the next day it works normally.
this the package
########## sensori monitor consumi ######
utility_meter:
  consumo_giornaliero:
    source: sensor.shelly_em_consumo
    cycle: daily
    tariffs:
      - f1
      - f2
  consumo_mensile:
    cycle: monthly
    tariffs:
      - f1
      - f2
  consumo_annuale:
    cycle: yearly
    tariffs:
      - f1
      - f2
###### input number per costi ######
input_number:
  costo_f1:
    name: Costo Energia elettrica Fascia 1
    min: 0.001
    max: 0.500
    unit_of_measurement: '€'
    initial: 0.068
    mode: box
    icon: mdi:currency-eur
  costo_f2:
    name: Costo Energia elettrica Fascia 2
    min: 0.001
    max: 0.500
    initial: 0.068
    mode: box
  consumo_mese_precedente:
    min: 0
    max: 1000000
    step: 0.01
    mode: box
    unit_of_measurement: 'kWh'
  consumo_mese_precedente_f1:
    min: 0
    max: 1000000
    step: 0.01
    mode: box
  consumo_mese_precedente_f2:
    min: 0
    max: 1000000
    step: 0.01
    mode: box
  costo_mese_precedente:
    min: 0
    max: 5000
    step: 0.001
    mode: box
    unit_of_measurement: €
  consumo_anno_precedente:
    min: 0
    max: 1000000
    step: 0.01
    mode: box
  costo_anno_precedente:
    min: 0
    max: 5000
    step: 0.001
    mode: box
########## input_boolean per tariffa weekend ######
input_boolean:
  tariffa_weekend:
    name: Tariffa Week-end/festivi
    icon: mdi:calendar-range
########   orari inizio F1 ed F2  #########
input_datetime:
  f1_ora_inizio:
    name: "Orario Inizio Fascia 1"
    has_date: false
    has_time: true
    initial: '08:00'
  f2_ora_inizio:
    name: "Orario Inizio Fascia 2"
    has_date: false
    has_time: true
    initial: '19:00'
###### sensore per giorni feriali e festivi  #######
binary_sensor:
  - platform: workday
    name: giorni fascia elettrica
    country: IT
######  sensori vari #####
    sensors:
      costo_consumo_oggi_f1:
        friendly_name_template: "Costo Consumo Oggi fascia 1"
        icon_template: mdi:currency-eur
        value_template: "{{((states.sensor.consumo_giornaliero_f1.state | float) * (states.input_number.costo_f1.state| float)) | round(2) }}"
      costo_consumo_oggi_f2:
        friendly_name_template: "Costo Consumo Oggi fascia 2"
        value_template: "{{((states.sensor.consumo_giornaliero_f2.state | float) * (states.input_number.costo_f2.state| float)) | round(2) }}"
      consumo_totale_oggi:
        friendly_name_template: " Consumo Oggi "
        icon_template: mdi:counter
        value_template: "{{((states.sensor.consumo_giornaliero_f1.state | float) + (states.sensor.consumo_giornaliero_f2.state | float)) | round(3) }}"
        unit_of_measurement: 'KWh'
      costo_consumo_oggi_totale:
        friendly_name_template: "Costo Consumo Oggi"
        value_template: "{{((states.sensor.costo_consumo_oggi_f1.state | float) + (states.sensor.costo_consumo_oggi_f2.state| float)) | round(2) }}"
      costo_consumo_mensile_f1:
        friendly_name_template: "Costo Consumo mensile fascia 1"
        value_template: "{{((states.sensor.consumo_mensile_f1.state | float) * (states.input_number.costo_f1.state| float)) | round(2) }}"
      costo_consumo_mensile_f2:
        friendly_name_template: "Costo Consumo mensile fascia 2"
        value_template: "{{((states.sensor.consumo_mensile_f2.state | float) * (states.input_number.costo_f2.state| float)) | round(2) }}"
      consumo_totale_mensile:
        friendly_name_template: "Consumo mensile"
        value_template: "{{((states.sensor.consumo_mensile_f1.state | float) + (states.sensor.consumo_mensile_f2.state | float)) | round(3) }}"
      costo_consumo_mensile_totale:
        friendly_name_template: "Costo Consumo mensile"
        value_template: "{{((states.sensor.costo_consumo_mensile_f1.state | float) + (states.sensor.costo_consumo_mensile_f2.state| float)) | round(2) }}"
      costo_consumo_annuale_f1:
        friendly_name_template: "Costo Consumo annuale fascia 1"
        value_template: "{{((states.sensor.consumo_annuale_f1.state | float) * (states.input_number.costo_f1.state| float)) | round(2) }}"
      costo_consumo_annuale_f2:
        friendly_name_template: "Costo Consumo annuale fascia 2"
        value_template: "{{((states.sensor.consumo_annuale_f2.state | float) * (states.input_number.costo_f2.state| float)) | round(2) }}"
      consumo_totale_annuale:
        friendly_name_template: "Consumo annuale"
        value_template: "{{((states.sensor.consumo_annuale_f1.state | float) + (states.sensor.consumo_annuale_f2.state | float)) | round(3) }}"
      costo_consumo_annuale_totale:
        friendly_name_template: "Costo Consumo annuale"
        value_template: "{{((states.sensor.costo_consumo_annuale_f1.state | float) + (states.sensor.costo_consumo_annuale_f2.state| float)) | round(2) }}"
# attenzione!!! questo sensore serve per sapere quando è l'ultimo giorno del mese io lo tengo commentato perchè lo tengo nel file sensor.yaml
      giorno_del_mese:
#        entity_id: sensor.date
        value_template: >
          {% set dd = now().day %}
          {% set dm = now().month %}
          {% set nm = (as_timestamp(now()) + (24*3600))| timestamp_custom('%m', True) | int %}
          {% if (dm!=nm ) %}
          ultimo
          {% else %}
          {{dd}}
          {% endif %}
this automation
####### AUTOMAZIONI CAMBIO FASCIA##########
- alias: Cambio Tariffa F1 con festivi
  initial_state: on
    platform: template
    value_template: >-
      {{ states('sensor.time') == (states.input_datetime.f1_ora_inizio.attributes.timestamp | int | timestamp_custom('%H:%M', False)) }}
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: binary_sensor.giorni_fascia_elettrica
      state: 'on'
    - condition: state
      entity_id: input_boolean.tariffa_weekend
      state: 'on'
  - service: utility_meter.select_tariff
      entity_id: utility_meter.consumo_giornaliero
      tariff: f1
      entity_id: utility_meter.consumo_mensile
      tariff: f1
      entity_id: utility_meter.consumo_annuale
      tariff: f1
- alias: Cambio Tariffa F2 con festivi
  initial_state: on
    platform: template
    value_template: >-
      {{ states('sensor.time') == (states.input_datetime.f2_ora_inizio.attributes.timestamp | int | timestamp_custom('%H:%M', False)) }}
  condition:
    condition: and
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
      tariff: f2
      tariff: f2
      tariff: f2
- alias: cambio tariffa f2 giorni festivi
  initial_state: 'on'
    platform: state
    to: 'off'
  condition:
  - condition: state
    state: 'on'
      tariff: f2
      tariff: f2
      tariff: f2
- alias: Cambio Tariffa F1 senza festivi
  initial_state: on
    platform: template
    value_template: >-
  condition:
  - condition: state
    state: 'off'
      tariff: f1
      tariff: f1
      tariff: f1
- alias: Cambio Tariffa F2 senza festivi
  initial_state: on
    platform: template
    value_template: >-
  condition:
  - condition: state
    state: 'off'
      tariff: f2
      tariff: f2
      tariff: f2
- alias: Costi Consumi Mese Precedente
    platform: time
    at: '23:59:45'
  condition:
  - condition: template
    value_template: "{{(states.sensor.giorno_del_mese.state == 'ultimo')}}"
  - service: input_number.set_value
    data_template:
      entity_id: input_number.consumo_mese_precedente
      value: '{{ (states.sensor.consumo_totale_mensile.state | float) }}'
    data_template:
      entity_id: input_number.consumo_mese_precedente_f1
      value: '{{ (states.sensor.consumo_mensile_f1.state | float) }}'
    data_template:
      entity_id: input_number.consumo_mese_precedente_f2
      value: '{{ (states.sensor.consumo_mensile_f2.state | float) }}'
    data_template:
      entity_id: input_number.costo_mese_precedente
      value: '{{ (states.sensor.costo_consumo_mensile_totale.state | float) }}'
  - service: notify.jarvis
      message: >
        Report Consumi Mensili
        Consumo: {{(states.input_number.consumo_mese_precedente.state | float)| round(2) }} kWh
        Spesa: {{(states.input_number.costo_mese_precedente.state | float)| round(2) }} €"
- alias: Costi Consumi Anno Precedente
    platform: time
    at: '23:59:55'
  condition:
     value_template: '{{ now().strftime("%m") == "12" }}'
    data_template:
      entity_id: input_number.consumo_anno_precedente
      value: '{{ (states.sensor.consumo_totale_annuale.state | float) }}'
    data_template:
      entity_id: input_number.costo_anno_precedente
      value: '{{ (states.sensor.costo_consumo_annuale_totale.state | float) }}'
      message: >
        Report Consumi Annuali
        Consumo: {{(states.input_number.consumo_anno_precedente.state | float)| round(2) }} kWh
        Spesa: {{(states.input_number.costo_anno_precedente.state | float)| round(2) }} €"
