Error trying to connect my HAS installation to Tuya Integration
Can anyone help me with the error above?
Detalhes do log (ERRO)
Logger: aiohttp.server
Source: components/tuya/config_flow.py:72
First occurred: 13:01:54 (2 occurrences)
Last logged: 13:08:05
Error handling request
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/connectionpool.py”, line 703, in urlopen
httplib_response = self._make_request(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/connectionpool.py”, line 386, in _make_request
self._validate_conn(conn)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/connectionpool.py”, line 1042, in validate_conn
conn.connect()
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/connection.py”, line 414, in connect
self.sock = ssl_wrap_socket(
File "/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/util/ssl
.py", line 449, in ssl_wrap_socket
ssl_sock = ssl_wrap_socket_impl(
.py", line 493, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File “/snap/home-assistant-snap/541/usr/lib/python3.10/ssl.py”, line 513, in wrap_socket
return self.sslsocket_class._create(
File “/snap/home-assistant-snap/541/usr/lib/python3.10/ssl.py”, line 1071, in _create
self.do_handshake()
File “/snap/home-assistant-snap/541/usr/lib/python3.10/ssl.py”, line 1342, in do_handshake
self._sslobj.do_handshake()
ConnectionResetError: [Errno 104] Connection reset by peer
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/requests/adapters.py”, line 489, in send
resp = conn.urlopen(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/connectionpool.py”, line 787, in urlopen
retries = retries.increment(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/util/retry.py”, line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/urllib3/packages/six.py”, line 769, in reraise
raise value.with_traceback(tb)
conn.connect()
self.do_handshake()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/aiohttp/web_protocol.py”, line 435, in _handle_request
resp = await request_handler(request)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/aiohttp/web_app.py”, line 504, in _handle
resp = await handler(request)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
return await handler(request)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/security_filter.py”, line 60, in security_filter_middleware
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/ban.py”, line 81, in ban_middleware
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/auth.py”, line 236, in auth_middleware
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/view.py”, line 136, in handle
result = await result
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/config/config_entries.py”, line 180, in post
return await super().post(request, flow_id)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/http/data_validator.py”, line 73, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/helpers/data_entry_flow.py”, line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/data_entry_flow.py”, line 281, in async_configure
result = await self._async_handle_step(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/data_entry_flow.py”, line 368, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/tuya/config_flow.py”, line 92, in async_step_user
response, data = await self.hass.async_add_executor_job(
File “/snap/home-assistant-snap/541/usr/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/homeassistant/components/tuya/config_flow.py”, line 72, in _try_login
response = api.connect(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/tuya_iot/openapi.py”, line 198, in connect
response = self.post(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/tuya_iot/openapi.py”, line 316, in post
return self.__request(“POST”, path, None, body)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/tuya_iot/openapi.py”, line 266, in __request
response = self.session.request(
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/requests/sessions.py”, line 587, in request
resp = self.send(prep, **send_kwargs)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/requests/sessions.py”, line 701, in send
r = adapter.send(request, **kwargs)
File “/snap/home-assistant-snap/541/lib/python3.10/site-packages/requests/adapters.py”, line 547, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
