Not sure if this belongs on a Node-Red forum or here, but since it’s within a Hassio add-on I figured I would start here in case it’s related to the add-on. I am trying to install the chat-bot module into node-red and it is failing. To my understanding, the npm install should install all the pre-requisites if any are missing but that looks like it is failing and I am at a loss of what I am missing. Any help would be appreciated. The log from the addon is below:
11 Mar 10:52:07 - [info] Installing module: node-red-contrib-chatbot, version: 0.16.5
11 Mar 10:54:42 - [warn] Installation of module node-red-contrib-chatbot failed:
11 Mar 10:54:42 - [warn] ------------------------------------------
11 Mar 10:54:42 - [warn] npm WARN deprecated [email protected]: use node-fetch instead
npm WARN deprecated [email protected]: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
[email protected] install /config/node-red/node_modules/grpc
node-pre-gyp install --fallback-to-build --library=static_library
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://node-precompiled-binaries.grpc.io/grpc/v1.19.0/node-v57-linux-arm-musl.tar.gz
node-pre-gyp WARN Pre-built binaries not found for [email protected] and [email protected] (node-v57 ABI, musl) (falling back to source compile with node-gyp)
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! stack at FSReqWrap.oncomplete (fs.js:152:21)
gyp ERR! System Linux 4.4.50
gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “build” “–fallback-to-build” “–library=static_library” “–module=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-musl/grpc_node.node” “–module_name=grpc_node” “–module_path=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-musl” “–napi_version=3” “–node_abi_napi=napi” “–napi_build_version=0” “–node_napi_label=node-v57”
gyp ERR! cwd /config/node-red/node_modules/grpc
gyp ERR! node -v v8.14.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --library=static_library --module=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-musl/grpc_node.node --module_name=grpc_node --module_path=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-musl --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57’ (1)
node-pre-gyp ERR! stack at ChildProcess. (/config/node-red/node_modules/grpc/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
node-pre-gyp ERR! System Linux 4.4.50
node-pre-gyp ERR! command “/usr/bin/node” “/config/node-red/node_modules/grpc/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build” “–library=static_library”
node-pre-gyp ERR! cwd /config/node-red/node_modules/grpc
node-pre-gyp ERR! node -v v8.14.0
node-pre-gyp ERR! node-pre-gyp -v v0.12.0
node-pre-gyp ERR! not ok
npm WARN [email protected] requires a peer of bufferutil@^3.0.3 but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of erlpack@discordapp/erlpack but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of node-opus@^0.2.7 but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of opusscript@^0.0.6 but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of sodium@^2.0.3 but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of libsodium-wrappers@^0.7.3 but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of uws@^9.14.0 but none is installed. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install:node-pre-gyp install --fallback-to-build --library=static_library
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2019-03-11T14_54_42_158Z-debug.log
