Morning all
This has probably been reported several times, but I didn’t find a specific fix.
I had two updates today; core, and os. I opted for OS first, and when I tried the HA upgrade (to 2022.8.6), it flatly refused. I can’t even restore to an old backup, that also fails.
Home Assistant 2022.8.5
Supervisor 2022.08.3
Operating System 8.5
Frontend 20220802.0 - latest
I have added some logs if helpful:
547624513744] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 299, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, system is not healthy
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1713, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1750, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 301, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
