Error updating to 0.60 with fatal python error in /usr/lib/python3.6/encodings/__init__.py
I’m getting a fatal error when updating from 0.59.2 to 0.60. Log output is:
core-ssh:~# hassio homeassistant update
Success homeassistant/update
core-ssh:~# hassio homeassistant check
Error on homeassistant/check: starting version 3.2.4
specified group 'tty' unknown
specified group 'dialout' unknown
specified group 'kmem' unknown
specified group 'input' unknown
specified group 'video' unknown
specified group 'audio' unknown
specified group 'lp' unknown
specified group 'disk' unknown
specified group 'cdrom' unknown
specified group 'tape' unknown
specified group 'kvm' unknown
Fatal Python error: Py_Initialize: Unable to get the locale encoding
  File "/usr/lib/python3.6/encodings/__init__.py", line 1
    tx *);
SyntaxError: invalid syntax
Current thread 0x76f834d8 (most recent call first):
And I can see in supervisor there is also an error:
17-12-20 11:01:16 INFO (SyncWorker_9) [hassio.dock] Run command 'python3 -m homeassistant -c /config --script check_config' on homeassistant/raspberrypi3-homeassistant
17-12-20 11:02:14 INFO (SyncWorker_5) [hassio.dock.interface] Update docker 0.59.2 with homeassistant/raspberrypi3-homeassistant:0.60
17-12-20 11:02:14 INFO (SyncWorker_5) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.60.
17-12-20 11:09:45 INFO (SyncWorker_5) [hassio.dock.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.60 as latest
17-12-20 11:09:45 INFO (SyncWorker_5) [hassio.dock.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
17-12-20 11:09:50 INFO (SyncWorker_5) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-12-20 11:09:50 INFO (SyncWorker_5) [hassio.dock.interface] Cleanup docker images: ['homeassistant/raspberrypi3-homeassistant:0.59.2']
17-12-20 11:10:02 INFO (SyncWorker_9) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.60
17-12-20 11:10:16 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
Not really sure what’s going wrong, all the other updates I’ve applied have been seamless. Would appreciate any suggestions.
