Ralf
(Ralf)
July 8, 2020, 9:22am
1
just tried to start the update to OS 4.11 which is shown in the supervisor tab.
But i got “unknown error, see logs”.
I do not see any Log entries within Settings -> Logs.
Anyone can help me please?
I am running the latest versions of type Home Assistant OS (Supervisor 228, Interface 0.112.3)
Regards, Ralf
fedot
July 8, 2020, 10:50am
2
Hey Ralf, those logs will show you the issues inside Home Assistant (Core)
Take a look at Supervisor - System
Ralf
(Ralf)
July 8, 2020, 11:36am
3
@fedot : Thanks for this hint.
I see the following errors (tried several times):
0-07-08 09:11:57 ERROR (MainThread) [supervisor.hassos] HassOS update fails with: Installation error: Failed updating slot rootfs.0: Opening output device /dev/disk/by-partlabel/hassos-system0 failed: Device or resource busy
20-07-08 08:42:38 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<HassOS.update() done, defined at /usr/src/supervisor/supervisor/hassos.py:125> exception=FileNotFoundError(2, 'No such file or directory')>
File "/usr/src/supervisor/supervisor/hassos.py", line 148, in update
int_ota.unlink()
File "/usr/local/lib/python3.7/pathlib.py", line 1304, in unlink
self._accessor.unlink(self)
FileNotFoundError: [Errno 2] No such file or directory: '/data/tmp/hassos-4.11.raucb'
20-07-08 08:42:39 ERROR (MainThread) [supervisor.hassos] HassOS update fails with: Installation error: Failed updating slot rootfs.0: Opening output device /dev/disk/by-partlabel/hassos-system0 failed: Device or resource busy
20-07-08 08:16:55 ERROR (MainThread) [supervisor.hassos] HassOS update fails with: Installation error: Failed updating slot rootfs.0: Failed splicing data: Error reading from file: Input/output error
20-07-08 08:16:55 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<HassOS.update() done, defined at /usr/src/supervisor/supervisor/hassos.py:125> exception=HassOSUpdateError()>
File "/usr/src/supervisor/supervisor/hassos.py", line 159, in update
raise HassOSUpdateError()
supervisor.exceptions.HassOSUpdateError
Any hints what i can do? Should i file a bug?
EDIT: running the RPi version (on RPi3b)
Thanks, Ralf
fedot
July 8, 2020, 11:47am
4
hm, did you make sure there’s enough space left on your SD card?
Ralf
(Ralf)
July 8, 2020, 11:57am
5
i would state that i have enough space available:
malkie
July 10, 2020, 12:34pm
6
Hey,
I have the same issue on a RPI4. Enough space on the device.
Would appreciate if somebody has an Idea
Mario
skoki
July 14, 2020, 8:47am
7
i have the same error, running on VM
skoki
July 15, 2020, 1:39pm
8
i got it to work. it is updated to 4.11 by it self
after few attempts over past day or two, many restarts and trys
Ralf
(Ralf)
July 20, 2020, 9:20am
9
After several attempts it also run now for me.
Don’t know what is different, always started either by UI or Terminal.
/ Ralf
