Error: [waveshare_epaper:163]: Timeout while displaying image!
Hello, Im having issues with a device im trying to make, I have the following hardware:
  • ESP32 WROOM
  • DHT22
  • Waveshare 4.20 inch e-paper screen v2
The basic functionality that I want is to have the DHT22 do a reading every minute and then display the values on the screen, along with the time and date.
And Im getting the following error in my log, normally I would not mind the errors, but sometimes the values on the screen appear as not available and I suspect its related to the error, as the values keep coming uninterrupted to HA.
[18:34:04.824][E][waveshare_epaper:163]: Timeout while displaying image!
[18:34:04.827][W][component:453]: display took a long time for an operation (255 ms)
[18:34:04.830][W][component:456]: Components should block for at most 30 ms
[18:34:04.834][W][component:453]: api took a long time for an operation (264 ms)
[18:34:04.838][W][component:456]: Components should block for at most 30 ms
[18:34:58.235][D][dht:042]: Temperature 24.3°C Humidity 39.2%
[18:34:58.240][D][sensor:131]: 'Watechen Temperature': Sending state 24.30000 °C with 2 decimals of accuracy
[18:34:58.248][D][sensor:131]: 'Watechen Humidity': Sending state 39.20000 % with 0 decimals of accuracy
[18:35:00.319][D][homeassistant.text_sensor:017]: 'sensor.time_date': Got state '18:35, 2025-10-29'
[18:35:00.320][D][text_sensor:085]: 'HA Time': Sending state '18:35, 2025-10-29'
[18:35:09.595][D][waveshare_4.2v2:076]: Performing fast update
[18:35:09.823][E][waveshare_epaper:163]: Timeout while displaying image!
My yaml is as follows:
esphome:
  friendly_name: watechen-sensor
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "coolkey"
ota:
  - platform: esphome
    password: "uncoolpass"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Watechen-Sensor Fallback Hotspot"
    password: "ringoSTARR"
captive_portal:
external_components:
  - source: github://pr#6209
    components: [ waveshare_epaper ]
text_sensor:
  - platform: homeassistant
    entity_id: sensor.time_date
# Example configuration entry
  - platform: dht
    pin: 2
    temperature:
      name: "Watechen Temperature"
      accuracy_decimals: 2
    humidity:
      name: "Watechen Humidity"
      accuracy_decimals: 0
    update_interval: 60s
font:
  - file: "gfonts://Roboto"
  - file: "gfonts://Roboto Mono"
# --- E-Paper Display ---
spi:
  clk_pin: 18
  mosi_pin: 23
display:
  - platform: waveshare_epaper
    cs_pin: 5
    dc_pin: 17
    busy_pin: 4
    reset_pin: 16
    model: 4.20in-v2
    update_interval: 65s
    # reset_duration: 2ms
    lambda: |-
      it.printf(10, 10, id(font1), "Temperature: %.1f°C", id(watechen_temp).state);
      it.printf(10, 40, id(font1), "Humidity: %.1f%%", id(watechen_hum).state);
      it.print(10, 60, id(font2), id(ha_time).state.c_str());
This is mentioned on the PR and it doesn’t look like it’s fixed:
Dang, I did not see that.
Welp
